Cossie management parts and others
Old Jul 25, 2011 | 08:13 PM
studabear's Avatar
studabear
Default Cossie management parts and others
I'm starting to break the cabrios management and also a few other parts I'm not gonna need
I have 2 L6 ecu's, both have had wasted spark fitted and then removed, they work but as some of you know I have to keep them indoors in the winter, so for this reason I'm offering them as spares or repairs I've spent good money on them but would like £50 each, 1 had a fan fitted, I think I have the fan cover somewhere.
Jano's phase set up for cvh engine I purchased new genuine sensor from msd I would like £75 for the complete set (sensor, bracket and phase disc)
Crank sensor set up for cvh cossie management complete I would like £75 consisting of crank sensor (i paid £50 for a new 1) sensor bracket, bottom pulley, trigger ring and washer, and securing screws
I also have a spare trigger ring £10
and a spare sensor £10
Alternator setup, alternator, alternator bracket and belt looking for £50 all ready to bolt on (provisionally sold)
I also purchased a re con alternator but never needed it, I would like £30 for that (sierra cvh type to suit bracket set up)
Map sensor bracket £10, modded so only has 1 attachment for fixing to heater box
Ignition amp and heatsoak (amp is genuine part, not done 150miles from matt lewis) £35
3 bar map sensor, again genunine weber from msd £40
blue injectors £30
chip for 1.6cvh with blue injectors, fmic etc £40
pectal board for the chip and ecu £75 (provisionally sold)
or £120 as a package
I have a freshly skimmed flywheel for rs turbo £40 it cost me that to have it skimmed so basically you would be paying for machine work and getting a free flywheel (sold pending payment)
Rs turbo distributor for use with cosworth management, no internals, new cap and arm £25
Genunine gpa coil, probably done 600 miles £27 posted SOLD
I can bring parts to ford fair if it help, all prices are plus postage unless stated, sensible offers considered.
I have 2 L6 ecu's, both have had wasted spark fitted and then removed, they work but I have to keep them indoors in the winter, as when very cold the car would mis fire unless the ecu was warmed in front of a fan heater, don't know why this was the case,esp with 2 ecu's, the only thing in common was the pectal board and chip. so for this reason I'm offering them as spares or repairs I've spent good money on them but would like £50 each, 1 had a fan fitted, I think I have the fan cover somewhere. pectal board and chip not included.
Cheers Stu
Old Jul 25, 2011 | 08:32 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Hello mate, would you take £20 posted for the group a coil and can pay straight away??
cheeRS
Old Jul 25, 2011 | 08:36 PM
studabear's Avatar
studabear
I'm awaiting on somebody coming back to me for the coil at £25 posted, if he doesn't have it you can have it for £20 collected from ford fair if your going?
Edit to add, group A coil sold
Old Jul 25, 2011 | 09:11 PM
milesy23rst
PUG 306 GTI-6
Am not sure whether i am going m8 as its my 40th 3 days after so may have a heavy weekend lol
Old Jul 28, 2011 | 04:41 PM
studabear's Avatar
studabear
PM's replied to
15
Oct 7, 2015 03:43 PM
hopper350
Sep 4, 2015 12:53 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
