mk1 focus rs= are both fans supposed to come on?
Old Jul 24, 2011 | 09:42 PM
turborob's Avatar
turborob
Default mk1 focus rs= are both fans supposed to come on?
Hi guys,after a quick blast earlier today i had the bonnet up to check a few things and happened to notice that only the small fan attached to the rad was working........is this normal for the small fan to kick in first,then a few degree's more should the larger one come on??
Or should the both be coming on together at the same time??
cheers,
Rob.
Old Aug 10, 2011 | 07:56 AM
Zetecfiesta's Avatar
Zetecfiesta
one of them is for your aircon i believe, if you turn the aircon on it will kick in straight away.
Old Aug 21, 2011 | 03:18 PM
Rollinz's Avatar
Rollinz
air con- and rad fans
if things get too hot it will put them both on
Old Aug 21, 2011 | 08:24 PM
RichieST's Avatar
RichieST
Yup they are twin stage fans so one comes on first, then the other if temps continue to rise.
simonmcf
Sep 22, 2015 08:40 AM
Vacuman
Sep 11, 2015 11:37 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Adam Graham
Sep 6, 2015 06:04 AM
