Saph Parts, Comps, Big brakes, Spec R
Compomotive Mo's 8 x18 ET35 in white, Continental Sport Contact 3's, front tyres are good, rears have about 2mm left, alloys are very tidy. £750 I was open to offers on these but looking at the cost of them new I think £750 is a complete bargain !
Hi Spec Mega Monster brake setup, 360mm discs, 6 pot calipers, Calipers and bells are gold. Will check what pads and disc condition but all look fine. SOLD
4WD rear brakes, new calipers and grooved discs ( 2k old ) SOLD
Mocal remote oil cooler with Earls lines and fittings £150
Spec R Breather kit, 3 tanks, Aeroquipped with nuts with hidden jubilee's £400
Spec R Header tank SOLD
Spec R Water Swirl pot with hoses SOLD
Spec R Dump Valve £80
Pace turbo water cooler SOLD
Standard radiator £30
Twin fan units for above £20
S/S turbo to air filter hose £20
Chromed bonnet hinges SOLD
Samco lower water hose in red £30
Samco boost hoses x2 in red £50
Chromed strut brace, bit flaky on the sides £50
Mongoose 2wd exhaust system, turbo back, 3" bore, 4" tailpipe, only a few months old, has speak plug hidden on top of the tailpipe and the egt probe broke off on the downpipe £300 ( was £500 new )
T5 gearbox, no whines or crunches £350
2WD 7.5" Rear diff, 3.9 CWP, Millers LSD oil, recently rebuilt by Steve @ A1 gearboxes £350
White dial intrument cluster £40
More to follow and also pictures when I finish off stripping the car.
ALL parts can be posted with a 24 hour courier and I can also post worldwide at buyers cost.
Open to offers on some parts
Its on a large K&N but not the 4" type, filter is battered though tbh.
Rear coilovers look very tidy, not even been able to see the fronts due to the wheels and brakes but I will get some pictures as soon as its all off. I will check the receipts as they were fitted on the car before I purchased it.
Simply doesn't do anything. I am sure it did light up but the previous owner had removed it to see if he could see anything obvious and never plugged it back in when he refitted it.
