200 short block wisecos engine reduced
Jul 20, 2011 | 06:53 PM
whole car has been broken it was a moonstone blue sapphire have parts still available please email or call if something needed, i might have it
all prices are delivered uk
200 block with wiseco 91.5mm pistons 6 long studs (mountune), H section rods , arp big end bolts , knife edge crank with standard main and big end journals , fitted with high pressure oil pump. all new and built and torqued £1060 (£3500 to build this so a bargain)
bd 10 exhaust cam for 2wd drive head £35
2wd inlet manifold with throttle body painted in wrinkle black £40
2wd diff in good working order £80
you can email at
olivercole@ymail.com or ring me on 07950 571 586 thanks Olly
Reason: item sold
Jul 20, 2011 | 06:56 PM
interested in the brakes bud, have you any pics?
Steve
Jul 20, 2011 | 06:59 PM
Jul 20, 2011 | 07:06 PM
What radiator is fitted mate? Alloy? Standard?
Jul 20, 2011 | 07:15 PM
how much for the turbo if I collect? and is it internal or external gated also will it be a straight swap over for at t34 as in the rear housing is a 3 bolt fitting to the exhaust ?
Jul 20, 2011 | 07:20 PM
Quote:
Originally Posted by
Matt Baxter
at that sort off money it has to be external, cheap
Jul 20, 2011 | 07:23 PM
Jul 20, 2011 | 08:27 PM
cosworth parts specialist
i will have the gearbox mate . pm sent
Jul 20, 2011 | 09:12 PM
Danny.
standard rad mate with fans £40 deliverd if you want it no leaks
Jul 20, 2011 | 09:13 PM
t3 dan
What injectors you got ?
no injectors mate sold them a while ago
Jul 20, 2011 | 09:14 PM
Moonstone Steve
Steve
will post pics up tomorrow
Jul 20, 2011 | 09:16 PM
Matt Baxter
hi mate it be £720 if you collect its external it wont bolt triaght on but you can buy an exhaust housing to turn it to internallly gated and will then bolt up to the three bolt exhaust the housing is about 360 dollars this is what i was gonna get
Jul 21, 2011 | 03:11 PM
Jul 21, 2011 | 03:47 PM
How much for intercooler posted to Sheffield mate?
Jul 21, 2011 | 04:04 PM
kaking1982
£80 postage ! fook me
Aside from that they are some very good prices, very suprised that bottom end is still there at that money
What rods are in it ?
Jul 21, 2011 | 05:58 PM
JonnyBravo
na not £80 postage just makes more desirable for someone to come pick it up saves me sending it
not sure what rods a long time ago i got them i will hunt for the reciept must have it somewhere
Jul 21, 2011 | 06:02 PM
Thats fair enough mate, was only joking with you, some very good prices there
Jul 21, 2011 | 06:12 PM
hi mate who built bottom end???
Jul 21, 2011 | 06:18 PM
matt black
i built the bottom end i work for Ford Motor company building prototype engines so made sense for me to build it
Jul 22, 2011 | 12:39 PM
Jul 22, 2011 | 01:06 PM
Nice job you have then, i would like that
Jul 22, 2011 | 01:07 PM
whats the exhaust for. saph or escort. 2wd or 4x4
Ignore this. just re-read the first post lol
Jul 22, 2011 | 02:01 PM
What about intercooler then mate ?
Jul 22, 2011 | 05:03 PM
rsmat
sold already
Jul 22, 2011 | 05:25 PM
Jul 22, 2011 | 08:39 PM
What comp is the bottom end?
Jul 23, 2011 | 09:35 AM
mcbernie
pistons are 8.1 :1 so standard
Jul 24, 2011 | 09:08 AM
Jul 24, 2011 | 11:12 AM
If you've still got in a couple of weeks I'll more than Likely have the short block
Jul 26, 2011 | 11:01 AM
block
you still have it ?how much measures the crank ?is standar ?shipping in greece ?
Jul 26, 2011 | 12:10 PM
sierrafun
the crank measures standard, i will ship to greece if you pay for it
Jul 26, 2011 | 01:11 PM
whats the shipping cost for greece?
Jul 28, 2011 | 09:44 PM
Interested in turbo. Are you going to ford fair ?
Jul 29, 2011 | 05:26 PM
Jul 29, 2011 | 05:46 PM
Any pics of exhaust mate and what parts is it ie where does it bolt upto how many boxes any dents cheers mate
Jul 30, 2011 | 07:03 AM
burnhamshaun
i will get pics up later its for the whole exhaust down pipe right to the rear box it comes with clamps
Jul 30, 2011 | 09:43 AM
What's your location please?
Jul 30, 2011 | 02:39 PM
im in bexleyheath in kent
Aug 31, 2011 | 05:45 PM
Sep 1, 2011 | 10:08 PM
send me your number please i am intrested in the bottom end.
