Bleeding brakes
Old Jul 20, 2011 | 04:46 PM
Danwood79's Avatar
Danwood79
Question Bleeding brakes
Hi all
I'm having new discs and pads on the front of my car and having new rear discs, pads and calipers.
Is there a order to bleed the brakes when we have finished, the car will be on a 4 post lift or can put on a ramp lift if they need bleeding with load on the axles.
Thanks for any help
Dan
Old Jul 20, 2011 | 05:23 PM
dojj's Avatar
dojj
Resident Wrestling Legend
is it a cossie?
then use the pump to bleed the rears and the foot to do the fronts and don't let the resivour run empty
if it's the escort in your pic, then do the rears with your foot and then the fronts with your foot
Old Jul 21, 2011 | 07:44 AM
Danwood79's Avatar
Danwood79
Originally Posted by dojj
is it a cossie?
Yeah it's a Escort cosworth
Thanks for the reply.
Dan
Edit updated pic
Old Jul 21, 2011 | 08:14 AM
martysmartie's Avatar
martysmartie
As said, also when refitted apply the foot brake vigorously several times before applying the handbrake, otherwise it won't work properly.
I always start furthest away from the M/C and work my way in, i.e. the nearside rear first, then offside rear etc.
Martin
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
