Do FRS disks fit straight under standard S2 rst wheels?
they are 324x28mm discs, ive been told i need different caliper brackets, anyone got any info on fitting etc?
Thanks, Joe
Thanks, Joe
As said above, 300mm ST170 with a slight "skim" seem to be the best bet... They go under 16s with no probs!
Why not look into a brembo 4pot setup using the 300mm discs? For instance a Peugeot 406coupe uses 305mm discs with 4pot brembos...
i have cossie 4 pots to go on but they seem to much hassel at the minute, im going round silverston so need a quick replacement for the time being!
P.s what do you mean by a slight skim?
Joe
Joe
So to get this straight, Do focus st170 discs fit straight on without any modding? i take it i can use erst calipers or do i need st170 ones aswell?
Thanks, Joe
P.s what make discs and pads?
Thanks, Joe
st170 discs
st170 calipers or any mk3 mondeo calipers (pads are different tho)
brackets and bolts from ebay Ł15 i think
Here's a pic of my 285mm cossie setup:
You'll see there is plenty of room for the disks, the issue you'll have with anything bigger than this is clearance for the caliper. As luke19790_3 said though, you can skim some Mondeo calipers to fit, up to you if it's worth the hassle. I'd just fit the cossie 4 pots if you already plan to fit them.
Lee
Lee
Billy_RS
16
Oct 11, 2025 09:41 PM
track.focus'd
Aug 12, 2015 05:53 PM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
only needed for 15's
