BREAKING escort cosworth (race car)
After a heap of thought i have decided to break my Cossie. My car was build for the start of last years race season. The car and parts have basically done nothing. The reason for selling is because of a new house needed. The car was a 55 second car round Knockhill on treaded tyre and would do 54sec on slicks. I just had my engine built in April and its done around 50miles. If you want pictures then give me a email c.reid444@hotmail.co.uk and will get pictures for the parts ur interested in. Any questions just PM.
ENGINE- £7000 (50 miles been done)
Harvey gibb built bottom end
long studded block
fully lighten & balanced bottom
forged pistons, valve cut out's and 7:8.1 c/r
Neil Roper ported and polished head, 25mm inlet/exhaust ports, double valve springs, new valves and guides, bd14 inlet, standard exhaust cam.
Vernier pullys
Modifed inlet manifold with plenum spacer
reyland alloy fuel rail
83lbs siemens injectors (reyland fuel rail)
2wd exhasut manifold with trouser spacer
GT30-71r (4" inlet) turbo with uprated bearing housing (internal wastegate)
Air injectors
ECU- MSD (L8 closed loop)
Modified 5 stud downpipe to suit turbo
gated sump
HP oil pump
new water pump
Brand new sensors all round
New alternator
powersteering pump
Bara dog box- £4900 ( Was bought few months ago and only done 2race meets at Knockhill and Bara will confim this)
3.6 standard Rear diff- £180
4x4 exhaust manifold- £60
OMP steering wheel boss- £20
GAZ golds (550lbs front- 350lbs rear) - £680
Adj TCA's-£50 ( in good condition but i damaged the ball joint rubber removing them)
Steering rack with solid mounts and rose jointed track rod ends (spare rose jointed Track rod ends and solid rack mounts)- £140
powder coated Front ARB with powerflex bushes- £80
Concentric top mounts with Custom strut brace to suit -£100
GrpA coil (like new)- £20
GPA K&N Filter (brand new still in wrapping)- £110
GPA K&N Filter (used)- £50
Bailey header tank(BLACK)- £100
Roose water hose/aux kit(BLACK)- £100
Gt30 filter hose (blue)- £40
Gt30 filter hose with recirc take off (black)-£40
Bailey DV30 (black)- £60
New Mocal oil cooler with hoses & s/plate-£100
Mocal spare oil cooler-£60
Mongoose 3" exhaust with centre section removed- £180
x2 Front hubs- £150
Almost new x2 front driveshafts with uprated CV's - £120
x2 rear driveshafts- £50
Propshaft with new bearing/ donut - £60
Front propshaft- £30
Earl's aeroquip (-6 &-8) fittings,bulkheads,adaptors and braided fuel hose to do full car and swirl pot system. £550
Fuel swirl pot- £60
Colins Monitor- £280
STACK st700 (white face)- £300
Spare genuine Escort cosworth rear Quarter- £500
Escort cosworth SHELL- £4000 (£4500 with top mounts, fuel lines and fuel swirl pot)
When i got my car set up on the corner weights it was sitting at 1160kg
Full respray in white (inside and out)
The shell is Fully seam welded with weld in roll cage and extras added
figerglass lightweight bonnet, tailgate, spoilers, front and back bumpers / splitters
Morrettes
roof scoop
carbonfibre door cards
polycarbonate windows
All the wiring has been replaced and custom wired to suit car/dash
Lightweight baffle/foam filled fuel tank with custom fire wall surround.
Brake lines run inside car
Custom dash fitted
Bias pedal box
Modified strut tops to take adj top mounts.
Mini DVR 3 bullet in-car camera (brand new still in box) -£190
You mite think im asking to much for some parts but the car has just been built really and done nothing.
P.S the prices above doesnt incl postage and open to sensible offers
long studded block
Vernier pullys
Air injectors
gated sump
HP oil pump
new water pump
New alternator
powersteering pump
x2 Front hubs- £150
Fuel swirl pot- £60
Morrettes
roof scoop
Custom dash fitted
Bias pedal box
Im offshore at the moment so cant get pics up but once im home i will. Yeah the clutch comes with cover and thrust bearing. Any parts ur interested in people then just PM me. cheers chris
Yeah no probs wil get pics when I can Graham. Neil it's a 71/2" rear beam but I run a 7" diff with little spacer I made up with no probs. Hi John yeah bit gutted to sell but has to be done. I wil be back with mini tho. I'm ment to get trophies for nxt race buy believe it when I see it lol
Andy and charlie were doing 50sec's. Lets just say there cars were in a different league haha. The sports and saloons are a shambles and not proper racing. Its down to who has the most £££££ that wins, not driver.
Im Just building a Mini to race in the Scottish Mini cooper cup....PROPER RACING hahaha.
All going well im wanting to do the last two races at Knockhill.
