metering head unit
Old Jul 14, 2011 | 09:23 PM
michaelward's Avatar
michaelward
Default metering head unit
does anybody know how to adjust the metering head plate cheers
Old Jul 14, 2011 | 09:32 PM
escoskmv's Avatar
escoskmv
there is a hole in between the meaterin head an the air filter,some have a tube thing bolted on an some just a hole. there is a alen key screw wich you can addjust. screw it in(clockwise) to push the flap down. or just take it and have it tuned mate
Old Jul 14, 2011 | 09:38 PM
michaelward
that just alters the co2 mixture the flap on my metering head is sat 2 high up
Old Jul 14, 2011 | 10:00 PM
escoskmv's Avatar
escoskmv
apart from that i dont think there is any addjustment on it. the plate is bolted to the arm wich pushes the plunger on the bottom of the meaterin head. strip it down an have a look inside make sure its all as it should be mate
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
rs_jim
Sep 19, 2015 08:41 PM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
