[L8 300hp+ Chip] 3bar map+T34.48+803s
Removed from my ECU as i wanted MSD chip with anti lag.
Performed fantastic. Its originally a superchips p0 but its been over written with a new map from an unknown tuner but AFRs were spot on, never went lean and gave good fuel economy when cruising.
330 Sort of spec as its for 3 bar, T34.48 turbo, Dark green 803 injectors.
Ran 1.2bar peak with 1bar of holding boost on standard amal valve.
simple plug and play chip for standard weber babyboard in l8 ECU.
Great cold start, good idle, drove spot on no problems at all I just wanted the anti lag.
JUST TO CLARIFY THIS IS FOR THE CHIP ONLY! make me an offer
£100ono posted or can bring to fordfair
