Re-Painting Inlet Manifold Tips?
Stripped apart my inlet earlier on, just wondering if anyone has any tips for prepping it.. Used engine degreaser/thinner and all the rest of it but its still bloody dirty.
Planning on spraying it with VHT paint. It doesnt need primer apperently but I still want to make the prep work better than it already is! How can I get rid of all the dirt/grime?
Any tips??
Thanks
Any tips??
Thanks
Im going to be doing the same on my own in the next few weeks , i'll let you know how i get on ! I used a few different wire wheels and tfr on the block when i painted that , and it has come up really nice ! Only time will tell though but looks good so far !
ill use urs yeah?
its easy mate, do u use a photobucket account? when you move the mouse over the picture it comes up with a little drop down box.. just go to the one that says IMG Code .. looks like
you just paste the line underneath whatever your typing then press enter so its like a seperate sentance
first up, dont bother spending the extra for VHT paint, normal will be fine, inlet manifold wont be getting so hot that it needs any special paint
when i did mine, i just stripped it completely, and cleaned it up using thinners on red scotch, which removed most of the surface tarnishing. you wont really ever clean it up completely without blasting it though, so dont worry about a bit of crap left
i used an etch primer to make sure it adhered to the surface properly. then just base colour rattle cans, plus lacquer. oh and the face that mates to the head, i just used 2 inch masking tape across it and trimmed it with a knife to the right shape, then when i was done painting i went over it with 1500 wet n dry to clean it all up nicely
hope that helps
hope that helps
hope that helps
hope that helps
heres a pic of how its looking right now
maybe try a bit of brake cleaner on there to blast some shit off. then just red scotch, then whatever is left just leave, etch primer will cover it ok. then just as many coats of base as u want really, cos on crackle effect it all depends on how much crackle u want based on how heavy and what direction the coats are
Hi mate
Are there any blast shops near you as having it blasted will save you so much time & sore finger ends.
Having it blasted witl alu oxide or glass will give you the perfect etch for primer & paint.
It will also clean up all the nooks and crannies that you cant get into.
We blast everything first before we paint or powder coat items etc.
Below are some we have restored to concours spec.
Chris
Chris
carb cleaner and brake cleaner are kind of the same thing really, only i use brake cleaner as its a quid from the local pound shop lol. obviously im talking just for cleaning shit up, dont go using brake cleaner in carbs just incase, but for cleaning an inlet, its what i did and it worked fine
i did mine without the need for blasting and it came up just as good as all my other parts i did have blasted previously. so long as its cleaned thoroughly and etch primed, the finish will be nigh on identical
I`ve just done mine, cleaned it with Gunk and a tooth brush. A light sanding a wipe over with thinners and primed with etch primer. I wanted to keep it looking standard so i painted it Ford Strato silver. Then laqured.
caprixpack
Sep 25, 2015 07:53 PM
