4x4 front diff, properly studded wih strengthening plate £150
Very mint cosworth 4x4 front diff, this has been properly drilled tapped and studded using M8 studs as it should be before then being fitted with a strengthening plate
I have not used the diff myself so it is sold as seen, i bought it as a good used working order diff, and drilled and tapped it myself before fitting the plate, looks mint and there is no play in it at all, any inspection welcome
Cover Plate can be taken off of course for full inspection etc
About a strong as you can make a standard front diff
£150
collection only due to weight but you can arrange your own courier but i will add £10 for time and materials to package the diff and you must take full responsibility for it during transit and make sure adequate insurance is in place etc
£150
The photo's of the empty diff case are just to show the studding being fitted and strengthening plate, this was my spare casing i done ready for uprated diff to be fitted,
I dont currently have any pics of the built up 1 with the cover off
xr4x4rs
Aug 6, 2015 09:03 PM
