3dr 205 Block - how much power???
Old Feb 11, 2005 | 03:04 PM
neal1980's Avatar
neal1980
Default 3dr 205 Block - how much power???
Hi, im about to take the plunge and rip apart my 3dr engine I aquired for a project. I intend to do a low comp rebuild, do you def need to change to a 200 block for around 400BHP, ive seen several articles in fast ford etc of cars producing this power whilst still using the 205 block...If anyone has a big power 205 block I would be interested in knowing about it..
Thanks
Neal
Old Feb 12, 2005 | 06:39 PM
dark3drcos.kickass's Avatar
dark3drcos.kickass
you don't need it i wouldn't of said it's just preferable, when rs500's were touring cars 200's weren't heard of, but i may be wrong
Old Feb 12, 2005 | 09:02 PM
swerv's Avatar
swerv
RS500's had different 205 blocks, very similar to the 200 blocks so you cant really compare the 2.
when you strip your engine and check the condition of the 205 block take it from there.
Old Feb 13, 2005 | 11:58 AM
pugo's Avatar
pugo
apparantly a certain mr rouse said they preferred using the oldest 205 blocks they could find as they seemed less prone to cracking than new 500 blocks, it wasn't until later that they used the 500 block.....once they had put some serious miles on them and heat cycled them many times
but if i was going to use a 205 block (which i do) then i would check across the block to head face for cracks(they usually go around the head bolt holes), then i would shine a torch down the waterways looking for heavy corrosion on the outside of the liners...the cleaner the better
Pugo
Old Feb 13, 2005 | 04:11 PM
neal1980's Avatar
neal1980
Cool thanks for the advice, should give me the power i need then in my series 2....time to get the welder out me thinks
Nov 1, 2015 06:53 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
DavidK
Sep 27, 2015 02:55 PM
