Turbo coolant hose - help drivin home in 5 mins!!
Old Feb 11, 2005 | 02:20 PM
Hrsturbo's Avatar
Hrsturbo
Default Turbo coolant hose - help drivin home in 5 mins!!
After thinking my radiator was fucked I now seen that the metal pipe going to the turbo has split Has to be towed home now!!
S2 escort by the way.
Where can I get a new one? Do they do braided?? How much £££??
Thanks
Old Feb 11, 2005 | 02:23 PM
CabrioTurbo's Avatar
CabrioTurbo
yo wont have to tow it just block off the water feed to the turbo!
Old Feb 11, 2005 | 02:25 PM
Hrsturbo's Avatar
Hrsturbo
Ah So clamp the hoses leading to it????
Good idea, will this work??
Old Feb 11, 2005 | 02:36 PM
Graceland's Avatar
Graceland
Team HOTHOT!
join em up together would be a better idea - use a bit of 8mm microbore copper pipe
Old Feb 11, 2005 | 02:39 PM
Toe Knee's Avatar
Toe Knee
Nooooooooooooo!!!!!!!!!!
If its anything like a cossie one which i assume it is cos a turbos a turbo u have to bypass the hose going to the turbo coming from the stat housing (its like that on a cos not sure if it goes to it from there on a S2 aswell?!) and bypass it back to the header tank instead of the turbo pipe!!
otherwise you wont get water flowing back to the header tank and it'll overheat and go bang!!!!
Could be wrong but as i say thats what you have to do on a saph!!!
Old Feb 11, 2005 | 03:08 PM
Hrsturbo's Avatar
Hrsturbo
oh shit dunno wot goin on now! I have clamped either side of the turbo - One tube comes from the main pipe off of the water pump and the other goes to the rad in the middle!!
Will this do me to get home 20 miles
Old Feb 11, 2005 | 03:15 PM
Hrsturbo's Avatar
Hrsturbo
bttt
Old Feb 11, 2005 | 03:24 PM
CraigN's Avatar
CraigN
too knee a rst is nothing like a saph so your just worying the guy
either do as graceland says and join the water feed from the top hose and the water hose form the rad or put a bolt and a clamp in the water feed from the top rad pipe and also a bolt and clamp in the hose going back to the radiator
Old Feb 11, 2005 | 03:26 PM
Bypass it not just clamp it ideally, that way it still flows the same
Hrsturbo's Avatar
Hrsturbo
ok thanks - I can now drive back without worrying Do they do braided ones or do I have to order shitty metal pipe???
Off home now sticking under 2k
Old Feb 11, 2005 | 03:34 PM
CabrioTurbo
shitty metal pipe it is im afraid... good lluck getting one...
i bet ford dont have any
Matt Baxter
Sep 16, 2015 08:30 PM
jaimesdna
Aug 25, 2015 06:59 AM
muffster
Aug 17, 2015 08:17 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
Escortdriver1
Aug 13, 2015 05:55 PM
