Does anyone know if the timing will move if the timing chain tensioner is removed to fit a new gasket to it on the granada cosworth boa engine?
Thanks.
the tensioner piston, i believe, fits in kinda like a bayonet. you have to twist it or something to get it out, i read it somewhere. but i pulled mine out from inside.
Take the Allen plug out, then place the Allen key into the hole and turn a quarter turn it will click, then as they say fitting is the reversal of removing
