what turbo would you suggest ?
GT2871R 53.85mm 71mm 400 HP
thats what i just cut and paste from a garret dealer so dunno
as for cut back blades aint that just an upgrade from standard ? im new to all this detail
oh right like i said im new to the details i was just going by what i was told on here recently that all these gt30 and gt28 followed by other numbers where different examples of 30 and 28
Ian, fantastic curve, what spec motor was that?
That really is awesome for a 400bhp motor.
Chip, here is the engine spec.......
ENGINE
200 COSWORTH BLOCK
STANDARD STEEL CRANK, STANDARD STEEL CON RODS
GENUINE COSWORTH PISTONS
LOW COMPRESSION (7.6:1)
HIGH PRESSURE OIL PUMP
BIG WINGED SUMP (1 litre extra)
WRC METAL 4 LAYER HEAD GASKET
LONG STUDDED
4X4 POLISHED & PORTED HEAD
HARVEY GIBBS CAMS
KENT ADJUSTABLE VERNIERS
PORTED INLET MANIFOLD AND PLENUM
INLET MANIFOLD ‘O’ RINGED
4X4 EXHAUST MANIFOLD
GT28 ROLLER BEARING TURBO WITH MODIFIED T34 FRONT HOUSING
GARRETT –31 ACTUATOR
GROUP A CAM BELT
GROUP A COIL
GENUINE RS500 INTERCOOLER WITH MODIFIED T34 FITTINGS
PACE RS500 FAST ROAD RADIATOR (50mm core)
PRO-ALLOY SLIMLINE UPRATED COOLING FANS
PACE TURBO COOLER
BAILEY MOTORSPORT TURBO OIL FEED & PRE FILTER
SPEC-R GROUP A BREATHER/SEPARATOR SYSTEM
SPEC-R CAMBELT COVER
SPEC-R SWIRL POT
SPEC-R WATER COOLED POWER STEERING TANK
SPEC-R HEADER TANK (with sight glass)
SPEC-R WASHER BOTTLE
STANT 21-25psi RADIATOR CAP WITH LEVER RELEASE
SAMCO BOOST & WATER HOSES
BRAIDED FUEL HOSE -6 WITH EARLS FITTINGS AND CLAMPS
(from filter to fuel rail, and regultor to tank)
MIKALOR STAINLESS STEEL HOSE CLAMPS THROUGHOUT
2 AIR SCOOPES ABOVE INTERCOOLER WITH DUCTING TO AIR FILTER
MONGOOSE 3in STAINLESS STEEL EXHAUST (with Powerflex hangers)
K&N GROUP A CONE FILTER
WEBBER MARELLI LEVEL 8 ECU WITH PECTEL BABY BOARD
PECTEL 12 POSITION BOOST CONTROL (in car)
4 X 403 GREY INJECTORS (503cc)
WRC AIR INJECTORS WITH –4 BRAIDED HOSE AND EARLS FITTINGS
ENGINE
200 COSWORTH BLOCK
LONG STUDDED
HARVEY GIBBS CAMS
GROUP A CAM BELT
GROUP A COIL
PACE TURBO COOLER
SPEC-R SWIRL POT
Ian, fantastic spec, and it certainly works extremely well judging by that graph, and i bet (not shown on the graph of course) that as well as a slightly better spread of rpm being on boost that the lag when you nail it at say 4krpm from a slight thorttle is also less than a standard T34?
I really wish id gone down that route with mine rather than buy the T34 now to be honest.
I assume that the t34 mods to the GT28 are largely responsible for it flowing more than one would expect?
Who did the work?
Or is it DIY?
Who did the work?
Or is it DIY?
Originally Posted by Fast Guy
gt28 wont flow 400 horses, not even the disco potato one (gt28rs)
Or failing that its just got a fantastic engine attached to it, after all my mates BBC makes 550bhp N/A off a carb, but your YB never will, lol
"Safe" on the boost map for a GT28RS is about 350bhp
Chip, All the work was done by Harvey at SCS
The original spec I went for was a T34 with a genuine .55 housing, as I didnt want much if any lag, but the spec changed come dyno day when Harvey unexpectedly bolted the GT28 on, and when I saw the figures it stayed
On the road, if you nail it from 2500rpm its INSTANT boost, and since it has been live mapped, it peaks at around 2.2 bar, backing of to around 1.8/1.9 to 6000rpm, then tails off.
Here is a pic on the dyno and in the car.......
WERY NICE FIGURES there ian
I would go for an gt-30 witch is also aa little more laggy then the gt28( not much tho) but is has the possibillity to go a little further in the future when you want a little more power
But either way, go for the gt28 or gt30....
Matt Baxter
Sep 16, 2015 08:30 PM
