mk2 rs clutch issue whilst driving hard
Old Jun 27, 2011 | 08:37 PM
big hyndy's Avatar
big hyndy
Default mk2 rs clutch issue whilst driving hard
ive noticed whilst on the motorway going through the gears at higher revs the clutch pausing on the floor for a second, ive always thought this was just the way the car gave a safe gear change?
just in from a wee drive round the town and i was tailed by a big spec scooby so off we went started to get a bit of a advantage then changed into 4th from about 6000rpm took my foot off the clutch and it stayed there, and stayed there until i selected 5th and it came straight up?
needless to say the scooby drove right past!
has anyone had the same problem or know if its a fault?
Old Jun 29, 2011 | 01:49 PM
2001ode's Avatar
2001ode
Hi,
Standard issue, and nobody knows where from.
Bad bleed clutch liquid, too hight rev, spring pedal, clutch cover, ???
Claude.
Old Jun 29, 2011 | 04:20 PM
big hyndy's Avatar
big hyndy
so its a common fault claude? not a technical fualt with just my car?
i ran the same road yesterday at the same speed and revs and selected 4th without it being an issue?
annoying more than anything!
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
englandbrad
18
Aug 6, 2015 09:24 PM
