Inlet manifold which is best s1 or s2?
"Ill check the stock"
yeh i want advise on matching it to the head, i know i need to drill and fit dowels so it goes on in the same place every time i have a basic idea there, the head is already ported, also as you say it splits, so would like to know what areas to work on etc
Any advice will be strongly appreciated.
Both wont be ideal.
2.0zvh with a 1600 head and MFi manifold and management system...
The 1600 engine runs out of puff due to the head. Fitting a larger cc bottom end isnt going to help.
Be better fitting an EFi management system, at least you will get the most out of the engine.
Both wont be ideal.
Johnny Knoxville
Sep 30, 2015 07:21 AM
caprixpack
Sep 25, 2015 07:53 PM
