whats wrong with this picture
Jun 26, 2011 | 10:59 AM
Jun 26, 2011 | 11:01 AM
Last Time, Get Off PF FFS
Jun 26, 2011 | 11:06 AM
Quote:
Originally Posted by
kosienutter
holy fuckin shit.
i said something similar to that mate
Jun 26, 2011 | 11:12 AM
Just a rocker cover gasket, just stick some tissue in the plug holes to absorb the oil.
Jun 26, 2011 | 11:13 AM
serious gaket fail
Jun 26, 2011 | 06:03 PM
Given that it's a Cossie I'd say that's quite normal and there's nothing wrong
Jun 26, 2011 | 06:24 PM
I'm surprise it didn't miss fire all over the place with the HT leads swimming in oil.
Rich
Jun 26, 2011 | 07:39 PM
Sonic Boom
Rich
It didn't miss once mate you've got to love a cossie lol
Jun 26, 2011 | 07:45 PM
Jun 26, 2011 | 08:03 PM
Glenn.
Its only a bit of oil.
That's what I thought. The gaps for plugs 1 and 2 on my zetec always have a bit of oil in, going to change the gasket when I paint my rocket cover.
Jun 26, 2011 | 10:17 PM
Jun 26, 2011 | 11:31 PM
That looks alright seeing as most ford's usually that oil would be where you last parked
At least its still in the engine
Jun 27, 2011 | 06:48 AM
Johnny
Are you running std cams bud?
Regards, Stephen.
Jun 27, 2011 | 07:11 AM
Jun 27, 2011 | 04:48 PM
Jun 27, 2011 | 04:52 PM
easy to get the oil out of there just take the plugs out and it will drain away, it'll smoke you say, its a cossie prob smokes anyway.
Jun 27, 2011 | 06:17 PM
S.Hannah
Johnny
Regards, Stephen.
Yes mate the whole engine is standard
Jun 27, 2011 | 06:38 PM
Christ! Bit of oil there ain't there? (slight understatement).
Jun 27, 2011 | 07:15 PM
mine was the same mate due to badly fitted gasket by previous owner i only noticed mine when it began pouring out of the little hole at the back of the rocker cover going all over the exhaust and causing a large amount of blue smoke to pour out of my bonnet vents!
Jun 27, 2011 | 07:18 PM
Had similar on the Escos recently, just a poorly fitting cam cover gasket. mop it up with tissue and clean the plugs-wack on a new gasket and away you go. there will be a lot of smoke to start with but should clear in a few mins
Jun 27, 2011 | 07:23 PM
Chopper1981
ive put a new gasket on there and checked the next day and oil on the ht lead again
Jun 27, 2011 | 07:27 PM
i used a metal gasket on mine that has a special rubberised coating on it, with it being metal there is no way it can move when putting the bolts back in far far superior to a standard gasket and re useable too
Jun 27, 2011 | 07:34 PM
johnnysierra
Did you put a little bit of sealer on when you fitted it to help hold it in place and clean the suface of the head and cam cover? easy for the gasket to move or a little bit of shit stops it fitting right.
Jun 27, 2011 | 08:41 PM
yeah i put sealer on the gasket but it must of moved
Jun 27, 2011 | 08:52 PM
Unreal, not seen anything like that before. Hope you get it sorted out ok.
Cheers,
Grant
Jun 27, 2011 | 08:58 PM
Mine did exactly the same as this, turns out that where a cock had scraped the previous gasket off they had gouged the cover and it was leaking through there. I had to use a gasket and sealer to cure it.
Mike
Jun 28, 2011 | 11:30 AM
johnnysierra
Its just that i dont see the groove on the inlet cam and was wondering if it was running different cams.
does the timing marks point towards each other on the two cam pulleys?
Regards, Stephen
Jun 29, 2011 | 08:43 PM
JP i've still got a 100 quid and my porn collection for it?
Jul 1, 2011 | 10:05 PM
Phil2002
forget the £100 just give me the porn lol
Jul 2, 2011 | 07:19 AM
mine does that, about every 5 minutes, even with a cometic gasket. must be a warped rocker on mine.
Jul 2, 2011 | 07:45 AM
I had the same leak 3 years ago,with a new Cometic and Loctite Seal its still ok.
Jul 2, 2011 | 07:54 AM
you do know that new oil goes in the plug marked "oil" dont you
Jul 2, 2011 | 01:22 PM
Joshy
so thats what im doing wrong lol
Jul 2, 2011 | 01:30 PM
wonder how many cossie owners have the same problem and dont know it bet its a few.
Jul 4, 2011 | 10:07 AM
johnnysierra
sweet i'll wipe it all off hire a luton and drop it off!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Mar 5, 2021 06:08 PM
A.t.p
Oct 23, 2015 07:54 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
DavidK
Sep 27, 2015 02:55 PM
