Mounting mtx75 to cvh
Old Jun 20, 2011 | 07:40 PM
J1mbo's Avatar
J1mbo
B1mbo
Default Mounting mtx75 to cvh
Hello folks, I'm taking the plunge and going mtx75
Im getting a diesel gearbox as I like the ratios, is this ok?
Next, the starter and flywheel set up, what do I use?
And lastly the clutch?
I'm new to this so please help
Cheers folk
Old Jun 20, 2011 | 07:47 PM
studabear's Avatar
studabear
rs2000 box might be easier
Old Jun 20, 2011 | 07:54 PM
crazycage's Avatar
crazycage
Cheers folk
focus rs clutch standard 2.0l flywheel
mondeo mtx box ( there front starter) focus mtx is rear and hits the starter motor.
Old Jun 20, 2011 | 07:58 PM
stuart collins's Avatar
stuart collins
just changed the centre on the clutch and used everythin else on mine dont no wat box mine is really long gears about the same finial drive as 3.3 on a bc box , do a bout 160 in 4th
Old Jun 20, 2011 | 08:01 PM
crazycage's Avatar
crazycage
sounds like you have a diesel box mate they have a 3.41 fd
Old Jun 20, 2011 | 08:03 PM
J1mbo's Avatar
J1mbo
B1mbo
Diesel box will take a focus rs limited slip diff then guys?
I've got a cossie four paddle clutch just don't know what to do about cover and flywheel
So I need a focus cover with a cossie four paddle and a 2.0l flywheel will that work crazycage?
I thought the zetec used bigger flywheel bolts?
Thanks for your help guys its appreciated!
Old Jun 20, 2011 | 08:04 PM
J1mbo's Avatar
J1mbo
B1mbo
Ps, the car will be running full boost with this gearbox so in the region of 270lb ft and 300bhp just to bare in mind when talking about clutches
Old Jun 20, 2011 | 08:06 PM
Luca's Avatar
Luca
Lukesville
Sounds like a wise move Jimbo, just dont launch it at pod!
Old Jun 20, 2011 | 08:08 PM
COCHYN's Avatar
COCHYN
Jim's too afraid to take his own car up Pod
Old Jun 20, 2011 | 08:09 PM
crazycage's Avatar
crazycage
yes the focus rs atb will slot in with no probs.
scrap the cossie plate idea mate and just use a full focus rs clutch kit.
the zetec does have bigger bolts 1mm bigger ,you can machine some bushes to sort that or re-tap the crank.
Old Jun 20, 2011 | 08:15 PM
J1mbo's Avatar
J1mbo
B1mbo
Not a good idea launching a mtx luke? That was the plan!
You scared?
Crazy- expense mate, I can't justify focus clutches when I have cossie ones coming out my ears, any ideas for me for a cheap conversion with cossie clutch bud?
I think a 1mm bush may be small so might machine out the flywheel 3 mm bigger then bush it down to correct size,
So just a 2.0l zetec flywheel?
J1mbo's Avatar
J1mbo
B1mbo
Alan, if the box is ok it will get a few runs at pod
Old Jun 20, 2011 | 08:22 PM
crazycage's Avatar
crazycage
You scared?
they work tho mate ,ive yet to see anyone make a cossie plate do the job of holding big power on a zetec . you might be ok on a cvh.
and yes any 2.0l flywheel
p-s you can pic them up second hand now and then.
Old Jun 20, 2011 | 08:23 PM
J1mbo's Avatar
J1mbo
B1mbo
Like I say 270lbft I really want to use what I have here you know, it's literally brand new ap 4paddle!
Old Jun 20, 2011 | 08:25 PM
crazycage's Avatar
crazycage
sell it ! thats how i clawed the outlay back when doing my conversion.
Luca's Avatar
Luca
Lukesville
You scared?
Not scared just skint
Stripped the box down today - whoops!
J1mbo's Avatar
J1mbo
B1mbo
Is this what I want?
http://cgi.ebay.co.uk/Ford-Zetec-2-0...3#ht_500wt_922
And does it have the suitable 36-1 ring gear on for my cvh block?
Old Jun 20, 2011 | 08:26 PM
J1mbo's Avatar
J1mbo
B1mbo
Not a bad idea, ok so STD focus rs one or uprated?
Ring you in a sec!
Old Jun 20, 2011 | 09:31 PM
crazycage's Avatar
crazycage
Ring you in a sec!
yes the flywheel in the link is what you need, and standard or uprated mate .the standard one will take 330ftlb in a focus .
Old Jun 20, 2011 | 09:35 PM
J1mbo's Avatar
J1mbo
B1mbo
Ok, I want to do some drag strip stuff so what would you recommend? I obv want it to last as long as poss?
Or do you have a link to the bits I need clutch wise,
Cheers fella been a real help
Old Jun 21, 2011 | 06:45 PM
J1mbo's Avatar
J1mbo
B1mbo
Up ski for the crazy cage need a clutch sorting
Will go for the focus rs if I can't use a cossie plate on the zebec flywheel and a certain cover?
Just don't know which focus rs clutch to get if e above isn't possible!
Old Jun 21, 2011 | 06:48 PM
Luca's Avatar
Luca
Lukesville
Zebec ? You talking Northern again!
Old Jun 21, 2011 | 06:54 PM
Rick's Avatar
Rick
Link above says 170bhp engine - if it's an ST170 one then it's no good.
You need a flywheel and cluctch from a 2.0 l non ST or Diesel - i.e. anything that used an MTX box. It has the 36-1 pattern in the flywheel.
Rick
Old Jun 21, 2011 | 06:58 PM
J1mbo's Avatar
J1mbo
B1mbo
Cheers rick will have a look about for flywheel
Might have one at work
What do you think on clutch front? Like I was saying id love to run my cossie four paddle if poss as it saves me a shit load, so would just need to know if it fits and what cover to use
If not then I'll go with the rs clutch just need a link to which one I need!
Lol Luke its this poxy iPad!
Old Jun 21, 2011 | 07:07 PM
Rick's Avatar
Rick
Get rid of the 4 paddle. Use a std Focus RS clutch which will last forever and be much nicer to drive.
Rick
Old Jun 21, 2011 | 07:08 PM
J1mbo's Avatar
J1mbo
B1mbo
Will it take the power and full bore launches?
Also, what about the stage up from standard ap clutch, not the paddle though?
J1mbo's Avatar
J1mbo
B1mbo
Only reason I ask is they're similar prices I think!
Old Jun 21, 2011 | 07:13 PM
THEDMAN's Avatar
THEDMAN
Standard Focus RS or upgraded organic will suffice!
Old Jun 21, 2011 | 07:15 PM
J1mbo's Avatar
J1mbo
B1mbo
Cheers chaps, looks like I need to get saving for a focus rs ap clutch
Ooh one more does the focus rs ap cover go into the mtx75 bell housing as Christian and beccy couldn't get it too on a cvh?
Old Jun 21, 2011 | 07:17 PM
Rick's Avatar
Rick
Christian was using the RS2k box, and it won't fit in that.
Rick
Old Jun 21, 2011 | 07:18 PM
J1mbo's Avatar
J1mbo
B1mbo
Ooh, so my diesel van mtx75 should be fine?
Old Jun 21, 2011 | 07:21 PM
crazycage's Avatar
crazycage
i wont fit into the crap old rs2000 box but will fit any of the hydraulic mtx gearboxes .
i run the up-rated organic ap in zetec and ric runs the standard rs clutch both with no probs.
Old Jun 21, 2011 | 07:25 PM
J1mbo's Avatar
J1mbo
B1mbo
Ahh, mine is cable operated box with rod change?
Old Jun 21, 2011 | 08:05 PM
J1mbo's Avatar
J1mbo
B1mbo
Come on lads last hurdle
Old Jun 21, 2011 | 08:59 PM
rsbondy's Avatar
rsbondy
Ur diesel box is same box as rs2000 box just different ratio's.
Old Jun 21, 2011 | 09:25 PM
J1mbo's Avatar
J1mbo
B1mbo
So the rs turbo clutch isn't going to wor is it
Old Jun 21, 2011 | 09:26 PM
J1mbo's Avatar
J1mbo
B1mbo
Focus rs clutch I mean
Old Jun 22, 2011 | 08:55 AM
Ollie MK5 Turbo's Avatar
Ollie MK5 Turbo
You cant fit the AP clutch cover in a early MTX75 Box. (Rod selector type.)
Thats why Im not using AP.
Old Jun 22, 2011 | 09:05 AM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
I run a full focus rs 6 paddle on my rod change mtx I had to gring some of the inside of the bell housing away on my gearbox aswell as using 3 vibration plates welded together to space the box away from the engine I found out the hardway fucking around with cossie clutchs ect they dnnt work!!!!!!
I have an AP focus rs pressure plate forsale Jimbo and a 2.0l fly wheel all you would need to buy is a paddle or spinner
Pm me if you want to no anything else I have some pics of the bell housing ect!
Old Jun 22, 2011 | 10:52 AM
Ollie MK5 Turbo
How has spacing the engine away from the gearbox affected your CPS sensor, Starter motor and clutch throw?
The CPS sensor has some tight tolerances.
