Anyone got a parts diagram for pedal bar set up please
Old Jun 18, 2011 | 05:56 PM
EssexMikeSi's Avatar
EssexMikeSi
Default Anyone got a parts diagram for pedal bar set up please
Basically i removed all the pedal bar and servo to do a refurb on the whole lot and now i cant remem how it goes back together. Mainly the large spring under the servo on the bar etc.
Dont suppose anyone has any pics or anything do they?
Old Jun 18, 2011 | 07:40 PM
ROB7656's Avatar
ROB7656
theres an exploded diagram in the hayne,s manual if i remember rightly mate.
Old Jun 18, 2011 | 11:43 PM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
This might help a bit
Old Jun 19, 2011 | 10:26 AM
EssexMikeSi
Legend. Thank u so much mate!! Thats what i wanted to see, the way the spring went etc. Cheers
Old Jun 21, 2011 | 08:35 AM
s2turbsZVH's Avatar
s2turbsZVH
No probs - just lucking timing - i am doing my engine bay at the moment.
Any pictures of your progress as yet ?
Old Jun 27, 2011 | 07:55 PM
EssexMikeSi
Well, heres one here
and a few bits waiting to be fitted
and i did some painting the other day, not an amazing job on the servo but i didnt want to rub it down too much to be honest.
Old Jun 27, 2011 | 08:20 PM
stevealien's Avatar
stevealien
10 Year Member
mike that bay is looking sweeeeet fella.
but stop being lazy,and paint that servo properly whilst its out,or youll regret it mate
Old Jun 28, 2011 | 12:46 PM
dazrsturbo's Avatar
dazrsturbo
does anyone know if the spring on the servo is still available from ford??
Old Jun 28, 2011 | 06:05 PM
EssexMikeSi
Yeah i know Steve but where the thick original coating was peeling, i didnt want to really take it all off incase it maybe made a hole or something lol, only that area u see on the servo was 'crummy'.
Must admit this is the first time i had done any sort of spray painting with aerosols. I just gave it a light rub down to get rid of flaking then primered the whole thing then gloss blacked it.
Old Jun 28, 2011 | 06:07 PM
EssexMikeSi
Im not sure Daz, must admit i just rubbed mine down then painted it
Old Jun 28, 2011 | 06:11 PM
EssexMikeSi
Can anybody show me where the T piece for the brake lines bolts to on the passenger side here, doesnt use same bolt as the servo support bracket does it?
I can't remem how anything bolts back together as i took pics of it all when i took it apart but then the phone i used broke and i lost all my images, Dooohhhh!!!!
Old Jun 28, 2011 | 08:50 PM
Puss2's Avatar
Puss2
Formerly know as Puss
Yes Mike same hole as bracket
Old Jun 29, 2011 | 08:34 AM
dazrsturbo's Avatar
dazrsturbo
I'll find out about the spring on friday when I go into ford dealer, if not I'll rub mine back and paint it too!
Old Jun 29, 2011 | 10:15 AM
s2turbsZVH's Avatar
s2turbsZVH
Just found this on some old emails - proper parts diagram for what you are looking at.
As for the spring - with mine i just buffed it with a wire wheel and then got it rezinced, you can see it in this picture.
Old Jun 29, 2011 | 11:15 AM
s2turbsZVH's Avatar
s2turbsZVH
Finis for this part is 6153953 - no longer available from Ford no stock in uk/europe either according to the system.
Old Jul 3, 2011 | 10:01 AM
EssexMikeSi
Couple really stupid questions that someone will be able to help me with by looking at their car if they would be so kind
- number 12 on that diagram, thats a thick white doughnut like washer, does that go just behind the brake pedal, pretty sure it does, then number 13 goes infront of the pedal to clamp the bar coming through from engine bay. Is that right?
- and, the support bar for the brake servo assembly, does that bolt to the back of the bracket (number 3), or does it go between the servo and the number 3 bracket?
Sorry again for stupid questions but i want to get it right first time.
Old Jul 3, 2011 | 10:55 AM
Rob_DOHC's Avatar
Rob_DOHC
Your bays looking good mate, but don't fuck it up with that servo, i've got one kicking about which is in crinkle black if you don't want to prep it.
Or just get the paint stripper out!
and s2turbsZVH your bay looks in really good condition especially your slam panel etc, good car you have there mate. I wish i had done a bit more zinc plating when i was doing mine but i guess i can still get it done.
Rob,
Old Jul 4, 2011 | 10:22 AM
EssexMikeSi
Anyone able to look at their car today for me please so i can get this done this evening? Cheers
Old Jul 4, 2011 | 11:33 AM
Rob_DOHC's Avatar
Rob_DOHC
Behind i think. (fairly certain)
And number 12 sits on pedal nearest to you, so between number 11 and 12.
Rob,
Old Jul 4, 2011 | 11:35 AM
Rob_DOHC's Avatar
Rob_DOHC
By support bracket do you mean number 4 in the diagram btw? as the diagram shows that going between the servo and mount, i would have thought it would go behind so the servo sits flat on the bracket. But hey, what ever fits!
Rob,
DixieTheKid
Jul 23, 2023 10:16 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
Aug 30, 2015 08:07 PM
jdsjojo
Aug 26, 2015 10:09 PM
Steve Escos
Aug 24, 2015 07:56 AM
