Efi HT leads
Need ur help guys, does any1 no if xr2i plug leads are different from fiesta turbo leads?
The reason I ask is I've recently done an efi conversion using Ofab on my s2 van and I've had no joy getting hur started, I've got a spark but it's really weak and quite irregular, couple of people have asked if it is fiesta turbo leads that's on it as they think theres a difference in them compared to 2i ones,...
Can any1 shed sum light on this?
Alan
Alan
They're the same afaik. The only difference could be the length because of the inlets, but I believe they had the same length! AND the car should run with all EFI leads, even with OHV ones!
I think there the same. Im pretty sure the coil pack is in the same place. If you havn't already bought your leads i recomend Ford motorsport leads from MSD. Good leads for 35 notes.
The HT leads are the same although they change in colour. Some are red some are black.
I use Fiesta Leads on a YB and a CVH.
I DO NOT use cheap motorsport copy leads on any car!
The Youth.
Sep 30, 2015 09:59 PM
