Compression ratio - discussion
All new to me this and really would like to gain a little knowledge
Would basically like to know how you work out what the ideal ratio is what for what HP and turbo.
Also when taking in to account block height and skimmed heads
For example, when using a BB turbo with higher C/R map does it shorten the life of the turbo due to the heat
I have read through loads of C/R threads and it appears to make no sense at all, recommendations vary.
Have you read the 3 articles on compression ratio written by Stu?
http://www.motorsport-developments.co.uk/stus.html
Me and my mate have exact same spec cars.
Except I'm 7.5-1 he's 8.5-1
Between the gears, his car pulls better, less lag when re applying throttle. Both GT30's
Both cars similar 1/4 mile times, etc
