Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
cooling fans for a saph cosworth
Old Jun 6, 2011 | 03:10 PM
3dr cossie's Avatar
3dr cossie
Default cooling fans for a saph cosworth
i'm after the twin fan setup from a 2wd sierra cosworth, not the 2 stage jobbies, the ones where both fans run at the same time?
cheers Matthew
Old Jun 6, 2011 | 03:31 PM
rog's Avatar
rog
Not heard of this, are you sure one just isn't broken, even if you are correct would it not be easier just to rewire it and keep the same fans and save ££?
Old Jun 6, 2011 | 05:06 PM
3dr cossie's Avatar
3dr cossie
the plastic frame work i have is all broken, and one fan has a broken case. really late saphs and escort cossies run 2 stage fans i believe?
cheers Matthew
Old Jun 6, 2011 | 05:34 PM
JamesH's Avatar
JamesH
I have a set off a 2wd Saff if that's any good? Never really took any notice if they come on together or not though
Old Jun 6, 2011 | 05:53 PM
fraser9764's Avatar
fraser9764
They certainly come on at the same time on mine (2wd saph) as they are fed from the same supply.
Old Jun 6, 2011 | 07:53 PM
3dr cossie's Avatar
3dr cossie
might have some sorted, i'll let you know
cheers Matthew
Old Jun 7, 2011 | 09:29 AM
3dr cossie's Avatar
3dr cossie
sorted now
cheers
markk
Dec 2, 2021 06:59 PM
3dr cossie
11
Dec 21, 2015 03:38 PM
hydro st170
Ford Focus ST
Aug 28, 2015 01:26 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
