Datapost rims ??
Old Feb 9, 2005 | 11:54 PM
Dunccoss's Avatar
Dunccoss
Default Datapost rims ??
Does any one know what off set and width they are as iam thinking of getting some 17" mo / or other motor sport rims to replace the split rims.
2 are wider than the other 2, are they 9 x 16 and 8 x 16 ? its just that the car is in a lockup and i can not get to it very easy.
cheers dunc
Old Feb 10, 2005 | 05:31 PM
Dunccoss's Avatar
Dunccoss
bttt
Old Feb 10, 2005 | 09:17 PM
DazC's Avatar
DazC
Hi,
I have a set of the Datapost wheels and IIRC when I measured the offset, they was about 17mm. I will have to check again to be certain.
The wheels I have are 7 x 16 but won't fit my car as they are wrong offset. I have managed to get them to 22mm offsets but they are still not right for my car....
I was after a wider set to strip down and mix and match to get the right offset if you know of some available.
Old Feb 10, 2005 | 09:36 PM
Dunccoss's Avatar
Dunccoss
cheers dazC
Old Feb 10, 2005 | 10:01 PM
DazC's Avatar
DazC
Apparently my set are the narrower of a few sets.
Do you want me to measure the offsets again just to confirm? Dunno if the front are a different offset to the rears you see....
Old Feb 10, 2005 | 10:05 PM
Dunccoss's Avatar
Dunccoss
is you could that would be good mine have a bigger outer rim on them on the back or should they be on the front as it fwd ?
Old Feb 12, 2005 | 09:26 AM
DazC's Avatar
DazC
The deeper dish wheels are the front wheels. When I tried them on my car, the depper wheels seemed to have more clearance for the brakes.
I have also studied the Datapost car. It has the deeper ones on the front.
If you do decide to change the wheels, would you be interested in selling?
I will get measure the offsets over the weekend and let you know.
Old Feb 12, 2005 | 11:31 AM
Dunccoss's Avatar
Dunccoss
yes mate i would sell them, i love the look of them but 17" mo with slicks would be better for me as i cant seam to get the right size 16" slicks second hand and also new ones seam hard to get hold off and are alot of money.
jamie956
Sep 1, 2015 10:50 AM
Rich@rd
15
Jul 15, 2004 09:26 PM
bigmatt-s2rst
Jun 25, 2004 03:38 PM
32
Apr 23, 2004 01:28 PM
Feb 24, 2004 05:17 PM
