S2 Rear load compensators
Old Jun 2, 2011 | 10:40 AM
Eagles's Avatar
Eagles
Default S2 Rear load compensators
Can somebody tell me where I can buy rear compensators for a 1990 s2 rs turbo. Main dealer in Ireland are looking for 240 euro each ( not happening ). Have tried Burton power they dont have them, Europarts in Tyrone only have the lhs (100 pound) Finis code 6167298 lhs and 6167299 rhs.
Also front hub metal dust seals both sides, these are on the inside of the hub. Finis code 1591847.
Would be grateful of any info.
Shane
Old Jun 2, 2011 | 11:17 AM
luke19790_3's Avatar
luke19790_3
i removed mine, i use inline ones.
You can buy mine if you want
Old Jun 2, 2011 | 12:23 PM
Maxwell's Avatar
Maxwell
Irregular Poster
I think i still have mine!! If i havent threw them out i will send them to you!! Im going with a brake bias valve instead!
Old Jun 2, 2011 | 02:51 PM
Eagles's Avatar
Eagles
Luke 19790_3
Thanks for your reply, will keep searching if i have no joy I will get back to you...
Old Jun 2, 2011 | 03:45 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Eagles before you try finding some to fit, maybe do some research into why all the people have there ones for sale.
Its all about taking them off, not putting them on.
Old Jun 2, 2011 | 04:21 PM
Eagles's Avatar
Eagles
Sound advice VC, have to go back to the drawing board I think.I am getting ready do do a full resto, not doing a rear disk conversion, am keeping the drums.
Old Jun 2, 2011 | 04:30 PM
Rob_DOHC's Avatar
Rob_DOHC
Ford don't keep the dust covers any more, i just resprayed mine (weren't too bad!), i've also chucked my rear compensator's, but tbh if you are standard ride height etc and they are working they do the job fine.
Rob,
Old Jun 2, 2011 | 06:25 PM
Eagles's Avatar
Eagles
Rob,
They are working fine just that the springs dont look too good ( Rusty ).
Not standard height I have Koni top adj shocks and lowering springs.
As for the dust covers 1 is bad and the other is worse !
Shane
Old Jun 3, 2011 | 10:02 AM
Rob_DOHC's Avatar
Rob_DOHC
lol, thats a shit.
I would rebuild the compensator's if you want to keep them. get the body and spring sandblasted, paint the slave cylinder looking part, powdercoat the other parts and get the spring zinc plated. You could do all of that for well under Ł50 the pair and they would look better than new.
OR
Fit inline compensators
OR
Redo the brake lines, remove the ABS and fit a willwood bias valve.
Rob,
Old Jun 3, 2011 | 04:07 PM
Eagles's Avatar
Eagles
Rob
Plenty of options there, I probally will go down the re-furb route.
Thanks for the advice
Old Jun 3, 2011 | 04:08 PM
Rob_DOHC's Avatar
Rob_DOHC
No problems, best of luck
Rob,
S3an
Sep 26, 2015 11:39 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
S3an
13
Sep 13, 2015 10:01 AM
cossirob
Sep 3, 2015 09:17 PM
