Focus RS Brembo Calipers Price Reduced again £250
Hi Guys,
i am selling my Brembo Front brakes off my sierra as i have managed to get hold of a set of Tarox 6 pot brakes.
the calipers, discs and pads are all from a MK1 focus RS.
they will come with all the above plus braided brake hoses and brakets made to fit a 2wd sierra.
these are great calipers and are very good alternative to the more expensive kits.
i am looking NOW REDUCED TO £350
i am based on Poole, Dorset. i could post but it would be expensive due to the weight and insurance, but i can get a quote if you pm me your postcode.
before i fitted them on my car the calipers had a full refurb with new seals etc, the discs are nearly new and pads have over 50% left. The discs are EBC and the pads are EBC Yellow stuff.
contact me on 07590983456 or PM me.
thanks
Adam
thanks
Adam
proper intrested....
i have fully refurbed 2wd brakes with ferodo ds pads and drilled and grooved fast road discs..... some one buy mine and i will buy these???
and mine have done less than 1k
yes i understand all wheels are different but i was running a cheap set of 17" wheels not sure of the make but they are heavier than others i have had.
nope not after a swedish plenum thanks lol.
i had problems getting my 17x8 ET35 tsw hockenheims to fit with mine (mine are fiat coupe turbo calipers but exactly the same) i had to run 6mm spacers to clear the calipers and the outside of the caliper to inside of the rim is a fag papers gap
thanks for the info.... ive got 5mm spacers here just incase
there's a set of coilovers i was after as well that i can't buy
but it's either buy stuff for the car or send the kids to nursery so there's only ever going to be one winner
you may need to remind tho as i have a tendancy to forget
