Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
1999 1600 focus dials sweep
Old May 26, 2011 | 02:48 PM
xr3i_kev's Avatar
xr3i_kev
Default 1999 1600 focus dials sweep
hi guys i have a problem with my focus
every time i start it the dials all do
a full sweep then go back to normal
when driving occasionally stereo the lights
and all dials also die down (like a major drain on the alternator)
and car loses power
then all of a sudden it goes back to normal
can anyone point me in the right direction on
where to start looking
thanks kev
Old May 26, 2011 | 03:27 PM
RichieST's Avatar
RichieST
Dials doing a sweep on start up is usually a sign that your battery is on its way out. Could also be worth checking connections are tight and earth points etc are corrosion free. If you do change the battery make sure you get the right one, I think it is a silver calcium. If you don't then the smart charge system will kill a normal battery in no time.
Old May 26, 2011 | 09:33 PM
xr3i_kev's Avatar
xr3i_kev
hi and thanks for your info
i took a further look into it tonite and disconnected the 3 pin
plug on the alternator to find that 2 0f the pins were
snapped and had been bodged up with two bits of metal wedged
into the plug so i went and got another alternator changed it
and got one sweep after fitting then had stopped
but when left for over an hour or so it does one sweep
when starting again but the lights stereo etc have not cut
out and seems to have sorted that phoned the previous keeper
to find that he put a standard 063 battery he had in an astra
will this be causing the sweep and will this damage my electrical system ?
any more info on this appreciated
thanks
Old May 26, 2011 | 10:13 PM
RichieST's Avatar
RichieST
well you aren't supposed to use another battery that isn't designed for use with smart charge so it could well be at fault. Would put another battery on it and go from there!
Old May 26, 2011 | 11:00 PM
xr3i_kev's Avatar
xr3i_kev
ok cheers will try get one tommorow
thanks again for your info
much appriciated
Old Jun 13, 2011 | 08:12 PM
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
As suggested mine done the same fitted a new battery and now all sorted.
Regards
Tony
chowfornow
14
Jan 5, 2019 09:01 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Tank Mike
Sep 26, 2015 08:07 AM
