Spark Plugs
Old May 25, 2011 | 01:08 PM
Rogeyboy's Avatar
Rogeyboy
Default Spark Plugs
What does every1 run?
Im getting a slight misfire on boost, now ive upped my boost to just over 1bar...
Im on NGK BCR8ES atm... Standard Fiesta Turbo plugs as im on OFAC EFi
Old May 25, 2011 | 01:56 PM
haz87's Avatar
haz87
Motorcraft 071c's
Old May 25, 2011 | 02:18 PM
matthart's Avatar
matthart
Same ^
Old May 25, 2011 | 02:26 PM
Rogeyboy's Avatar
Rogeyboy
Ok cool... What gap do we reckon? I run a 1mm gap with the NGKs
Matt, Had to send the faulty beige back in the end, they reckon it had "developed" a fault between when they posted it and it arriving here... It was down to 100cc/min flow and incorrect spray pattern - so over 2 weeks after sending them off they are fitted and the car runs!
Old May 25, 2011 | 03:29 PM
haz87's Avatar
haz87
My gaps irrelevant as you know im n/a. I'd say realistically you could get away with 1mm still. BUT if this misfire is the spark being "blown out" then maybe dropping it to .9mm and seeing how you get on could be worth it
Old May 25, 2011 | 04:22 PM
Karlos G's Avatar
Karlos G
Balls Deep!
NGK BCR8ES for me too, gap is what they come out the packet with I think! lol
Old May 25, 2011 | 04:44 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Completely unrelated, but I think I recognise the Orion in your siggy - were you on the A11/A47 the other day? Think you had another Orion in convoy with you.
Old May 25, 2011 | 06:03 PM
juffer's Avatar
juffer
071c. For less than a tenner for a set there a great plug.
Old May 25, 2011 | 06:17 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
071c great plugs
Old May 26, 2011 | 12:02 PM
Rogeyboy's Avatar
Rogeyboy
Ive got a set of 071c's now, i'll give them a go and try a 0.7mm gap (thanks to stu @ msd)
I've always stuck with NGKs and never really ventured away, but i'll give these a go and report my findings lol!
Cosmeister, not recently on the a11/47... But i may have been on there at some point! The old girl hasn't ventured far outside of essex recently!
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
