MTX75 Gearbox Fitting guide into mk3/4
Ask me a question!
A few people have asked me to give them a guide on what and how to do it. So here is a link from 7 years ago. lol.
https://passionford.com/forum/genera...iveshafts.html
Ask me a question!
there is a trader selling lsd's at the mo for the MTX75 i see at a show which was around £225 which is a bargain. Worth buying and fitting if you want an LSD in the box.
Turbocharging Technician
Not really a guide lol, If i had pics of the ones i did i would show how i made the shafts in the machine shop (from mk5 escort ones) and how i made the gearbox mounts, also what speedo cable and clutch cable to use and from what car. Also how to modify the gear linkage from the mk3/4 to work with the mk5 one. And i would also document the flywheel and clutch upgrade.
I agree with your first comment mate, a few pics of how to modify the inner wing and pictures of drive shafts is more of an advert and less of a guide.
Rob,
When we did my mtx conversion in my mk2 fiesta I used a homebuilt top mount and an rs2000 rear stabilizer mount I used I mk5 escort gear linkage and we cut the tunnel from a mk5 escort and welded that in so that the linkage fitted spot on!
Pics
inner wing mods,
top mount,
rear mount setup,
custom sleaved shafts,
rs2000 tunnel,
and quaife LSD!
Pics
inner wing mods,
top mount,
rear mount setup,
rs2000 tunnel,
and quaife LSD!
Lol il have to see how long they last when they fail il have some solid ones made but untill that day il stick with these head choppers lol
RIB1122
Aug 13, 2015 09:09 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
lol, they will be fine IME
