Wouyld this gearbox fit?
Old May 22, 2011 | 08:43 PM
juffer's Avatar
juffer
Default Wouyld this gearbox fit?
Im going to be uprating to a mtx box in the winter but i want something to fill the gap between now and then. I have a mk3 anti roll bar fitted to my mk4 escort. Would this fit?
http://cgi.ebay.co.uk/FORD-ESCORT-1-...item2a100dc02a
Old May 22, 2011 | 09:07 PM
Rob_DOHC's Avatar
Rob_DOHC
I have fitted one, it seems to have the 4bolt mount for the mk3.
You need to be careful about release bearings, there is a thread about it somewhere. Other than that it bolts straight in.
I split mine in half and fitted my lsd (standard rst) went right in with some new bearings. I think i gave a best offer of £100 and it turned up in 2 days.
It doesn't come with a clutch arm, your standard rst one fits but you need the late type clutch arm bush (the grey one) ebay sell them so do burtons i think. Your rst speedo goes right in, you need to get a red speedo drive (ebay).
Gear change is very nice, and a few people have them with over 300brake and seem no to have broken them. Bigger bearings and a stiffer case seem to really help.
Good luck and let me know how you get on
Rob,
Old May 22, 2011 | 09:08 PM
Rob_DOHC's Avatar
Rob_DOHC
PS, the ratios seem a bit shite,
For standard rst ratios you need
The final drive out of an escort gti
The gear cassette out of a 1.4 mk4 fiesta
and the casings you have in that ebay add.
IMO the standard rst ratios are pretty good.
Rob,
Old May 23, 2011 | 05:58 PM
juffer's Avatar
juffer
I need to try and find a bit more info on the release bearing. Cheers rob.
Old May 23, 2011 | 09:16 PM
Rob_DOHC's Avatar
Rob_DOHC
No problems, i never found the right one, i was in a rush and machined the wrong bearing out, but its not quiet
I believe Jaiscossy (i think his used name is...) has fitted one too, and he found the release bearing. Best thing to do is buy the box, have a measure and call a few companys.
Rob,
Old May 24, 2011 | 06:22 PM
juffer's Avatar
juffer
do you know the gearbox ratios for the gearbox?
Old May 24, 2011 | 06:45 PM
Rob_DOHC's Avatar
Rob_DOHC
Sorry mate, i never found anything conclusive, i'll tell you more when its on the road.
Old May 29, 2011 | 10:31 PM
juffer's Avatar
juffer
One of these Bearings might fit rob. http://www.clutch-specialists.co.uk/...mber&x=51&y=14
Old May 29, 2011 | 10:37 PM
Rob_DOHC's Avatar
Rob_DOHC
Good stuff, I've got the part number for the one i have fitted (which had to be modified) i'll find it and pass it on. At least you will know thats wrong.
The seller was selling two models of box at one point so they may have different bearings?
Rob,
Chas
Sep 21, 2015 08:57 PM
RsS2daz
Aug 14, 2015 05:26 AM
RIB1122
Aug 13, 2015 09:09 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
RIB1122
Aug 3, 2015 09:20 AM
