spark plugs
Old May 22, 2011 | 06:24 PM
jimhc's Avatar
jimhc
big jc
Default spark plugs
how much power are the 071 spark plugs safe to use
Old May 22, 2011 | 06:50 PM
KSA-Cossie's Avatar
KSA-Cossie
up to 600 bhp mate
Old May 22, 2011 | 06:58 PM
As said, certainly a very hardy plug, not the best for running/smoothness but still excellent.
Old May 22, 2011 | 07:13 PM
jimhc's Avatar
jimhc
big jc
as there only a tenner thot be better using them instead of the ngk at 40quid a set. what do you mean by not best for runnin smoothness
Old May 22, 2011 | 11:05 PM
mechanic28's Avatar
mechanic28
use mine in my 500hp cossie,tabetha means as in they dont make the engine run as smooth as some like it can be abit uneven at idle etc
Old May 23, 2011 | 03:23 PM
You will get a better idle and slow speed running ime with the precious metal ones like iridium, but 4 times the price, I think it's worth it, still very good with the 071, just that little bit better imo/ime with IK range.
Fuelling needs to be spot on though as the IK range are hyper sensitive to fouling I've found and don't recover often if heavily sooted, and defo not if ever made wet.
Old May 23, 2011 | 09:12 PM
jimhc's Avatar
jimhc
big jc
the ngk foul up if left to idle to long. what do you mena by imo ime ik range
Old May 24, 2011 | 07:11 AM
imo = in my opinion, ime = in my experience.
If a plug is fouling when idling too long, either it is too cold a heat range, or the engine is far too rich, or a combo of both, I found the Nippon Denso IK31 plugs way too cold, so use IK27, as these are a hotter plug, but perfect for my needs.
Old May 24, 2011 | 12:03 PM
jimhc's Avatar
jimhc
big jc
pfr7b ngk plugs?
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
