high compression VS low compression
I prob asking something thats already been done to death. But what the benefits one against the other?? As i going to start a rebuild. thanks,
Turbo'd cars favour lower comp. Not sure of the specifics but higher comp leads to det. (a problem I am having at the moment which will be solved by piston skimming)
Less comp, more boost.
higher compression is better for low boost and n/a applications, partcuarly at high rpm, low boost the opposite.
basically if the compression is high and you get a good fill of the cylinder (ie low rpm and high boost) then you end up risking detonation unless you retard the timing an awful lot, and then that can lose you power
rally cars break the rules seemingly, but only because they run very high quality fuel which means that detonation is less of an issue
I suspect you would get EGT problems if you filled a WRC car with 97 ron fuel and remapped it to work on it, especially if you then held it under load towing a caravan up a hill or similar
high rpm -> high cr
low rpm -> low cr
low boost -> high cr
high boost -> low cr
yours is high rpm and high boost (doesnt even spool till over 4Krpm so certainly isnt low rpm) so is "middle" cr as a result, it doesnt need to be low compression because you arent making boost at low rpm, and it cant be high compression because you wouldnt be able to get any timing into it in the midrange.
If yours was low (ie under 8) you would lose loads of power on race fuel, if yours was high (ie over 9) you would lose out on road fuel.
Where Mark has put yours is a good compromise for the two fuels.
FYI (with regards to my comments)
Under 8:1 = low compression
8 - 9 = normal compression
Over 9:1 = high compression
There are other factors too of course, such as the flow characteristics of the head and the cams that are used which will also effect things, but unless he is doing anything very wild in those respects they dont really need to be covered by this thread particuarly.
As chip said rod 8.4:1 isn't really a high CR, modern FI engines are using over 10:1 in some applications, made possible with good combustion chamber design and direct injection.
The higher the compression ratio the more vital timing and fueling becomes, a low compression ratio is much more forgiving at highish boost than a high cr...
IMO an mfi car is better suited to a slightly lower CR at over 20psi due to less accurate fuelling/timing etc.
My car is a bit over 8:1, if i were to build it again i would use stock CR if not slightly higher.
Rob,
Rob,
As per what I said above mate.
high rpm -> high cr
low rpm -> low cr
high rpm -> high cr
low rpm -> low cr
Ever thought of being a teacher Chip, that makes sense & i understand it.
I had assumed over standard commpression was high & below 7.2 was low.
Turbocharging Technician
yeah, its a 9a 16v with mad cams and bike bodies running MS efi, just got it running, will be tuning it shortly, should be fun never tuned na before.
I mapped an over 300 degree cam engine last week that wanted to be low 13s in places where I would normally have prefered high 14s, but the difference in now it drove dictated what it ended up with.
And bear in mind you wont find peak ignition via det, you need a set of rollers.
If the cams are really mad dont be surprised if it wants to be richer than you expect down the bottom end.
Disclaimer: VERY vague figures for fucks sake dont just enter them and drive it around
At full throttle you are probably going to be in the region of about 25 degrees at 5000 (or where you make peak torque on whatever cams it is you are running) raising to about 30 degrees at 8000 (or whatever your limiter is)
Idle at about 10 degrees
Part throttle low rpm at 30 ish
And at high rpm at low throttle angles it will be about 40 as anymore than that never seems to help even though it wont det no matter what you do to it at those points on the map.
Interesting reading guys...
Chip - You really should be a teacher or an engine tuner (which im guessing you are?)
I always thought low comp was the way to go for Turbo engines, but i read that the lower the comp the more lag as less response you get. High comp boosts quicker and produces more power... I think i'll stick with standard comp on my engine after reading this - around 8.2:1?
high rpm -> high cr
low rpm -> low cr
high rpm -> high cr
low rpm -> low cr
as i cant see the problem with having a high compression ratio and reducing advance at high load to eliminate det as most modern cars seem to do?
As far as i understand it, CR vs Advance is a bit of a trade off, its whether a high compression ratio with less advance makes the same power as a low compression ratio and more boost. There are many obvious advantages to having a higher compression ratio.
Is that correct Chip?
If you do that on big boost, you will end up with high EGT's as a result.
Ahhh of course
Yes, but if you end up retarding the timing too much the power you are losing is because the burn hasnt happened quickly enough in the cycle so the energy ends up as heat rather than used to push the piston down.
Ahhh of course
Sorry, good point. I really meant retarding the timing to with in reason. CR and advance is still a bit of a compromise as far as i can see. As you have said above, lowering the compression ratio and advancing the timing will reduce egt's, but too much and you just loose power/drivability and make for a generally less efficient engine.
Its why you go to a recognised engine designer not just a builder to get an engine designed to what you as the driver require. It aint cheap it aint going to happen overnight but hell is it worth it.
....and they will say bin the cvh and use something way better, and you wouldnt have to look far for that now.
Not always true, Karl certainly wont for example as he seems to enjoy the challenge of the CVH, just a case of finding the right person who specialises in the engine you want built.
