2wd Manifold joint bolts
Info needed regarding the male torx bolt's that join the 2 parts together - where to get them or the sizes would be great cheers
Hey Brammer.
Hope this can help you out.
Ford Finis Code is. - 6163714 according to ecat.
think you can still get them.
ill check for you at 8:30 when the stealers open if you like
they are made from stainless steel and are either M8 x 20 or M8 x 25 Thread pitch 1.25
but i dont know what grade of material is correct for strength.
Regards, Stephen
Regards, Stephen
Bram NLA in this country unfortunately and I 've just sourced what I believe to be the last one, I'm going to use my overseas contacts to try and get my hands on as many as I can
Luciano
Luciano
You learn something new every day.
You could be right ill let you know when i find out.
Regards, Stephen
I've got a spacer between mine for the gt30 and the bolts supplied are stainless Allen key ones just longer so if they work with the spacer surely shorter stainless ones would be ok
As Tabs said, and when they were available they weren't cheap....not torx bolts either, just 12point head's
I broke one on mine many years back, so I just replaced them all with 12.9 m8 allen heads. I wouldn't use stainless as it has pretty naff shear properties...stick with hi-tensile.
As said DON'T use stainless, it has very low ductility, I personally would just use 12.9's in mild steel, they don't need to be done up mentally tight, just use with lots of coppaslip
and as said just regular 12 point jobs, I use a bog std 12 point socket on them, think it's 11mm ?
A few years ago when I took my turbo off all but one of the studs snapped off. I ended up drilling all four of them out and using M10 (IIRC) Stainless nuts, bolts and heavy spring washers.
As I say, it's been like it for a few years and has been absolutely fine; they haven't come loose, snapped and do not show any signs of fatigue.
Sod paying ridiculous amounts for Inconel fasteners.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
