focus st?
Old May 14, 2011 | 11:54 PM
maddog247's Avatar
maddog247
Question focus st?
I have a focus st 56reg wanted to know if the mk2 focus rs turbo will fit my car and also the mk2 injectors and ecu? If so who can install? Does anyone know?
Old May 20, 2011 | 03:22 AM
Paynee's Avatar
Paynee
the turbo and injectors should go straight in i think, not so sure about the ecu dont know if its coded for immobiliser or what. as for mudflaps i got some off ebay, not sure what they are like as i havent fitted them, couldnt bring myself to drill into the wings but i have bought some clips and will be fitting them in the next couple of weeks when i get home from work i will let you know what the fit is like
Old May 20, 2011 | 05:10 AM
simo2k2000's Avatar
simo2k2000
Turbo And injectors fit. ECU can be remapped so you don't need to swap
Old Jun 23, 2011 | 09:06 PM
Kampfkoala's Avatar
Kampfkoala
When u will fit the RS Mk2 Turbo on your ST Mk2 you need the oil feed lines from the RS.
Your stock lines will not fit.
I also think you have to create a new intake pipe from the RS Mk2 Turbo to your intake pipe.
Injectors fits without probs.
Regards
Alex
Old Jun 24, 2011 | 09:16 AM
thebigmacmoomin's Avatar
thebigmacmoomin
Why not just buy some mods for the ST engine, remap, exhaust etc...
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
