MSD fan switch temps???
sssssh Rick, i was hoping some one from msd would jump in and give me a few temps lol,
But yes im using my ecu, just built two outputs for two stage fan control
along with some launch/flat shift.
Cheers mate, i'll give it a go
Rob,
not sure temp wise but for reference on the guage mine kicks in 1/3 up.
Hope that helps
Hope that helps
Rob,
I always get annoyed with two fans switching on and off, the sierra uses a similar 2 fan setup and the temps are dead stable, less fan noise etcetc.
So im thinking one fan is (at the moment before i test it!) going on @ 87ish and off @ 84 and the other fan is kicking in around the 100 mark as above,
As long as them temperature is nice and stable (ie doesn't constantly over shoot then under shoot) then im happy, and if it turns out i don't need to individually control two fans then i have a spare programmable output to do something with
Rob,
Rob,
Hey fella according to the link they kick in 5-7c lower than stock which i believe is 89c ?? Which with the new switch would confirm what focus 4x4 has said . Heres the link anyway hope it helps !
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270739119742&ssPageNam e=STRK:MEWAX:IT
Lovely thanks very much mate, i saw their site but didn't know what the standard temp was
Tested my outputs and after a small hickup they are all working so i'll post up the temps i settle on after some weekend testing.
Rob,
Rob,
No worries . Im ordering a switch soon so i'll be interested to see what result you get as mine overheated like a biatch last time i was stood in traffic ! mind due the fans were'nt kicking in at all then so while im in the procees of semi rebuilding my engine i want it to run cooler than it did before ! Ie ...... Not cooking it tits off in traffic ! lol
Cool, maybe it will be fine with one output then. My sierra has independent switches for the fans and controls temp much better than my rst did. Trial and error should give some decent results.
Rob,
Rob,
Yes it needs wiring cutting cos the fan switch has his own wiring & plug and not match with the rs turbo fan switch plug......
As simple as cut wirings and fit new faston plugs male-female and job done.
Hope this helps....
i always thought 100c is getting too hot as i got a aftermarket temp guage and would start worrying wat are good running temps ? and when do things start getting dangerous ??
sorry to highjack rob but while we on subject i got msd switch so wiil try make note wat temp it kicks in and off at
Not a hijack at all mate. Its a pressurised system so the coolant boils at a higher temp around 110 deg c i think? Boiling coolant is dangerous as it severely hurts the systems ability to cool. So running at 100degC is safe, just not sure if it will hurt performance at all and stop me running as much advance.
Rob,
Rob,
i see thanks mate so wat is a good temp to be running at i know there are alot more factors to look into sitting in traffic, hot days but as a guide wat would you want as a average temp to see
My temps seem to rise quickly at low speeds, even when not booting it around. When my fans kick in they seem to take ages to cut off again... arnd 8-10mins. If i cruise along at 30-40mph the temps drop rapidly! Just got an airtec rad fitted, so i know thats all good - thinking more of an airflow prob over the rad?
Lol, thats the problem, i don't know yet!
But Rick makes a very good point above, if your coolant it over 100c then you stand a better chance of getting your oil above 100c which is good as it lets any water evaporate etc.
But, it the temps are too high i may not be able to run as much advance. I think im going to aim for 90-95 at the moment as its nice and safe and experiment more later.
Rob,
Do you run with front mount intercooler???
It will reduce airflow over the rad............
and less time fans on....
I traced my faulty fans on my 2dr Sierra back to the plug on the harness that goes to the switch. I have hunted high and low and not able to find the right plug for the factory sensor. Any ideas?
May have to grab an aftermarket sensor and plug and wire it in but would rather stick with the factory switch...or perhaps make a loom and use an Escort two stage switch. I am in Australia and being warmer like the idea of one fan kicking in around 82deg. I have seen thermostats that open earlier so will be grabbing on of them as well
Ive noticed according to tunerstudio/MS my fans kick in at 95c and go off at 91c...
Is that too high?
I do get alot of air come out between rad n intercooler when the fans r on... So they tend to stay on 4 ages 2 get the water temps to fall again.
Is that too high?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
rsguy
44
Sep 29, 2015 03:29 PM
