Inside Your Saph Cosworth :) Ideas please
Im going to start using my cosworth again but the interior needs a freshen up as my dad who used to own the car left it completley standard.
The car is completley standard minus the new escort cosworth monte wheels i have just put on it and a new radiator from auto specialists as the old one was knackered.
Just lookin for ideas to change dash etc wise ... any help would be appreciated
Also what mods would be best to see more power before it gets an engine rebuild as it has done over 120K miles ... without a problem ... which is a first for many cosworths on here
I would not personally be looking for more power on a standard engine, if I did the most would be stage 1, if it's never been touched something may let go, just imo, the HG is a weak item even with standard power!
Depends on what you are looking to do, a boost gauge can be handy but if standard I don't see the point personally!
You want to rewire the fans ideally and check the fuel pump voltage under load as a minimum!
Martin
Martin
lukeeboy149
Aug 22, 2015 04:29 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
