ofab air temp sensor?
Old May 10, 2011 | 07:59 PM
mikey_clough's Avatar
mikey_clough
Default ofab air temp sensor?
Does anyone know which wire goes to which sensor pin on the air temp sensor? Its ofab frst management.
thanks
Old May 11, 2011 | 11:20 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Looks like
25
15
Old May 11, 2011 | 10:02 PM
mikey_clough
is that at the ecu? do you know which colour wire goes to which pin on the sensor it self or does it not matter which way round they go? thanks
Old May 15, 2011 | 11:15 PM
pitjardas's Avatar
pitjardas
http://www.rsbible.co.uk/
OFAB
1, Red -- +ve
3, Brown/Yellow – octane / idle adjust
4, Brown/White – speed sensor
7, Brown/Green – engine temperature sender
8, Brown – CO adjust potentiometer
16, Brown – current return & 40
17, Brown/Green – diagnostics connector
20, Brown – current return
21, Brown/Yellow – idle speed valve
22, Brown – fuel pump relay
23, Brown/Red – octane / idle adjust
24, Brown/Blue – octane / idle adjust
25, Brown/Yellow – air temp sensor
26, Brown/Black – throttle sensor & co adjust pot & map sensor
27, Brown/Yellow – map sensor/via supressor
28, Blue/Yellow – Pin 2 on edis (disconnected)
30, Brown – current return
33, Brown/Green – Boost control valve
36, Blue/Red – Pin 3 on edis
37, Black – idle speed valve & injectors & Speed sensor & Boost control (tbc) & 57
40, Brown – current return & 16
46, Brown – map sensor & engine temp & air temp & throttle & CO adjust
47, Brown/Green – throttle sensor
48, Blue/Green – diagnostic connector
56, Blue/Yellow – Pin 1 on edis
57, Black – idle speed valve & injectors & Speed sensor & Boost control (tbc) & 37
58, Brown – Injectors
59, Brown – Injectors
60, Brown – current return
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
