Ecu cover....
Gary Krishna
Everytime anybody put anything in there, it just used to end up in their lap whenever I accelerated hard!
Put a 2wd ecu cover in there now as I prefer the look.
On my last sierra I lined it with rubber, this stops normal acceleration from battering your passengers with objects, but I know what you mean, I mostly had a 500ml bottle of water jammed in mine.
Most models had a stowage compartment, it was only models with certiain management that diden't (I think the DOHC may have as thats EEC) they later moved this on the facelift models and the compartment appeared again, I should think the dash is the same colour?
Martin
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
Sep 14, 2015 09:04 PM
