1988 crystal blue 2wd sapphire cosworth
1988 crystal blue sapphire cosworth 2wd
65,000 genuine miles,this was registered in the channel islands from new and I brought the car into the uk last year,so all duty is paid
there is no rust or rot on the car at all and its never been welded,ANY INSPECTION WELCOME
passed its first MOT and only required a steering rack boot and number plate light to Pass
there are a few pin dents and scratches on the car,but for its age its in fantastic condition
I waxoiled the inderneath as it was so clean I wanted to preserve it
the car has had green injectors,escort cossy big turbo fitted,along with 3 bar map sensor,associated chip,4x4 intercooler and 3 inch stainless exhaust,I fitted all new sensors 2 months ago including new plugs,rad switch,air temp,oil pressure switch,coolant temp and an aftermarket breather/catch tank
oil and filter was changed last month using 10w60 oil
I have receipts for a new turbo,new gearbox and engine rebuild
the engine runs perfect,no smoking,no bubbling headertank etc etc
engine,transmission and diff are leak free
comes with 17 inch rs wheels that have brand new yokohama perada tyres on and have done approx 80 miles.
grey cloth interior in good condition,MOMO wheel and gearknob,quickshift,boost,oil temp and pressure gauges
Gaz gold coilovers all round,poly bushed control arms,group A diff mounting
CAT 3 clifford alarm immobiliser with pager remote
LSD works as it should with no whines or leaks
brakes are standard but I have brand new discs to go on the front which I will do when the car sells.
I have a rs500 pace intercooler which I will include with the sale and some other bits and bobs like new arch liners and some interior bits
car is taxed and tested til end of year
BAD POINTS
wheels need refurb and balancing
central locking on rear doors and boot inop
no radio
rear electric window witch broken
Car is located in Ulverston Cumbria,I am the registered owner,genuine reason for sale
looking for £4450 NO TEST PILOTS AND BRING INSURANCE,LICENSE AND MONEY IF YOU WANT TO TEST DRIVE
Pm for phone number etc and more info
BAD POINTS
no radio
Oct 9, 2015 07:38 PM
rog
Sep 4, 2015 12:10 PM
