replacing window motor
My drivers electric window motor has packed in. The window is in the up position.
Is it just a case of drilling out the rivets and replacing the motor? Or is it a little more difficult?
Regards
Steve
Regards
Steve
the rivets hold the mechanism onto the door, the motor is attached by 2 bolts to the mech, so to change the motor, the mech needs to be removed
hope this helps
cheers Matthew
hope this helps
cheers Matthew
As said above, it's a easy if fiddly cramped job, use some tape to hold the window up and detach the mech from the rails off the bottom of the window, these just prise off.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
