Cosworth parts needed please, can swap/px
T34 compressor housing, (not restricted)
Turbo oil drain rubber hose
2wd steering joint
Oil temp gauge and 1/8th" sensor
Pro-alloy rad and cooler 63mm pipes
2wd steering joint
hello mate, i have a stack oil temp guage, stepper motor one. £85 and will come with a sump plug adaptor m14 thread
and i have a pro alloy rs500 cooler and alloy rad £650 for both
ic has 73mm and 55mm inlets - i also have some hardpipes and an msd fan switch that you can have if interested.
cheers
cheers
155lee
Sep 14, 2015 07:37 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
