oil cap seals
Old May 6, 2011 | 09:55 PM
c123s1turbo's Avatar
c123s1turbo
Default oil cap seals
hi all the oil rubber o ring on my oil cap has split and is allowing it to leak oil. would this cause it to be a pain to start from cold?
my s1 is struggling to start from cold when it does fire it runs lumpy and sometimes on 3 till i give it some revs.
someone has suggested that the oil cap not fitting air tight would cause this?
cheers
Old May 6, 2011 | 10:32 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Assuming your metering head plumbed into the breather system still,then yes this will cause hard starting and rough running due to excess air!
Replace the cap and that should fix your problem.
IainRS1700T
Sep 25, 2015 06:44 AM
krypton
Sep 23, 2015 07:29 PM
Brickhouse
Sep 21, 2015 11:00 AM
biggiejody
Sep 19, 2015 10:25 AM
hopper350
Sep 4, 2015 12:53 AM
