Sapphire cosworth parts
Compression struts £100
Comp brake adjustable Tcas, *£100
GGR GpA dumpvalve with K&N filter £90
Cam cover, powdercoat black £60
OE Bosch Dumpvalve £10
Ford racing Sparco pro2000 blue and silver seats, pair £380 cash
Chromed inlet and*Plenum £50
Cosworth steering rack 400miles only since overhaul £90
2x OBP pedal boxes £110 ea
Setrab 15row oil cooler £??
Ford original T34 Escos turbo hose, black rubber OE £30
Sapphire rinted rear door glass £??
2wd Thermostat housing £??
Pics to follow
OFFERS TAKEN, these must go
Pics to follow
The head measures about 138.6, it has cams and STD pulleys, water inlet fitting, belt tensioner bolt and temp sensor. It has 4x exhaust manifold studs missing. Great for spares
lukeeboy149
Aug 22, 2015 04:29 PM
