piston slap
Old May 3, 2011 | 09:02 PM
jimhc's Avatar
jimhc
big jc
Default piston slap
i have a 2wd cosworth the piston slap has been there since i bought the car but went away when warm now after av changed the oil to 10/60 fully syn oil the noise seems to be stayin alot longer and slight noise even when warmed up. the oil a was using was 10/40 fully syn only reason a used it was a had it sitting for my old car a sold
Old May 3, 2011 | 09:05 PM
botters's Avatar
botters
competant bodger
my car used to have noisy tappets on 10/60 and stupidly high oil pressure as well lol
since i changed to 10/50 its a lot quieter
Old May 3, 2011 | 09:10 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Always use 10/40 in mine.
Steve
Old May 3, 2011 | 09:35 PM
jimhc's Avatar
jimhc
big jc
pain in the arse think al change the oil again waste of good oil tho but worth it if the noise go,s
Old May 3, 2011 | 09:50 PM
botters's Avatar
botters
competant bodger
Steve
fully or semi mate?
Old May 3, 2011 | 10:01 PM
jimhc's Avatar
jimhc
big jc
its always ran fully
Old May 4, 2011 | 04:24 PM
I had piston slap even when warm, oil didn't help, yours may just be getting a bit long in the tooth, how many miles has the bottom end done ?, mine had 200K so was entitled to be noisy!!
Old May 4, 2011 | 07:35 PM
jimhc's Avatar
jimhc
big jc
77000miles. rebuilt 15000m ago roughly. if a,d a done 200k ad be noisy
Old May 4, 2011 | 07:47 PM
15,000 rebuild should be dead quiet, you sure it's slap you can hear, and not a lazy tappet that quietens down as the oil heats up ?
Old May 4, 2011 | 07:59 PM
jimhc's Avatar
jimhc
big jc
its a diff sound to a tappet a had them done on my old cossie
Old May 5, 2011 | 07:28 AM
Did you swap oil brands at the same time, some oils do seem to make the engine noisier than others ?
Old May 5, 2011 | 07:33 AM
jimhc's Avatar
jimhc
big jc
yeh a did a had millers 10w60 sittn when a had ma evo n thot al use that tae use it up
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
ajamesc
Sep 8, 2015 06:51 PM
