Headwork?
Before i ask this it's NOT one of Steve aka Cossie4i's attension seeking threads..
Genuinley would like to know, would headwork be REALLY benificial to my spec??
T35.55
205 Block
Seimens 72s
NMS Live map etc etc
It made 355bhp/360ft/lb @ 30psi when Mark rollered it @ Motorworx, so more boost to be had too if wanted
Just wondered what headwork and maybe a cam change would do?? or not worth doing ??
I guess the Turbo is the limiting factor to be fair....
Thanks.........
T35.55
205 Block
Seimens 72s
Thanks.........
i would leave the exhaust and smoth/flow the inlet a bit better
cams will just move the power around the rev range
4x4 inlet will help the responce a bit maybe with a spacer
but if your happy with what the car does now then save the money for a new camera lol
What a load of crap, head work will improve that spec, end of!
A big of work on the inlet and more so on the exhaust, a 14 inlet cam, would transform that engine and be a good 385/390 bhp
We do so many and a ported head transforms the way they rev and make power
i would leave the exhaust and smoth/flow the inlet a bit better (wrong way round fella, its easy to get air in harder to get it out, a STD yb exhaust port is quite poor!)
cams will just move the power around the rev range (not entirely true it will also make more(or possibly less of course) power not just move it)
4x4 inlet will help the responce a bit maybe with a spacer (add inlet volume for response?)
of coarse it will transform the engine noone is stupid enough to think it wont, but the cost would outweigh the gains compared to what else can be done.
thats how i always view tuning anyways cost against results.
So you just want a outright power engine? Fair enough bang a bigger turbo on there.
Want a more responsive, more revvy engine, and more power for less boost and less stress on your engine then get a ported head
Not to mention your gt3071 is the best part of a grand or more,
For a grand in headwork, head gasket, Top end rebuild you will make your engine 100%
That in my books is better than another 40 bhp or what ever it makes
come on jimbo weigh up the price of headwork, then weigh up price of gt30 like cossierich has, gt30 will yield much more power.
I picked up 40hp and 50ftlb on a ported head over a cossie rich spec engine.
Mark
the only reason i can afford the supra at 30 is because i roll my money on with cars, when it looks like im gonna loose money i sell and atleast break even. i guess im a tight arse but ive had lots of cars through my life and they havnt really cost me sod all BUT i fear that is all about to change
lol
im getting ganged up on now
lol
Lol you know how I feel on here sometimes
I see what your saying, but working with a tuner I guess I see the right way of doing it, and the way to make a engine better is deffinately freeing up the head as its just no good on a yb either way, the awnser to the OP is porting would be worthwhile
To get much more than richs spec it then becomes worth it, The engines are deff better on a ported head but yes it does come down to cost/worth it but you will struggle at this level.
Mark
i totally agree it transforms the engines behaviour ive had 2 t4 ybs, proper rs500 t4s one ported head and one standard, standard head was strangled and surgeing until 5500rpm then it was fine whereas ported head pulled smooth 28 psi straight in no surge. i guess it depends if you want an all out no expense spared build or cheapest bang for buck.
op if you can afford it full head job and gt3071, or biggest gain for smallest ŁŁŁŁ wack on a gt3071 and sell the t34.55.
Fook me, this thread's taken on some pace, So basically you're saying, (well some of you)
EVEN with a simple Spec like mine headwork will improve it's current state? i knew this BUT i just wanted to know how much and if it was/is worth the cost...Cheers folks..
PS, Can the 2wd Inlet Manifold allow for 380-400bhp too?? where's it's limits??
That's sold to Matt....
Steve, i honestly don't want over 400bhp mate, i've been there with the saff & my Evos near 500bhp those, a lovely 380-390bhp with similar torque does me fine now matey, i reckon i have good room for improvement here listening to Mark and Jimbo etc...
For me Steve it's not just about making the extra 40bhp/40/ft/lb, the drive on mine i want to improve, it seems a tad laggy imo for the Turbo, should be coming on boost better than where it is, around 3900-4k...
The 4x4 inlet would of helped mate
Steve
Yeah it's a strange one Steve, defo around that rev range it seems, it's over 3500 anyway.
The 2wd one will be ok for my needs Steve, yes obviously the 4x4 would be better, but if the 2wd is ok upto 400 then hey -ho..
Im sure i gained about 10bhp and 10lb/ft when i swapped mine over.
Was on 400s at the time.
Was also done on the same RR.
Steve
FPMSLLLLLLLLLLLLLLLL
Now that is POT KETTLE if i've heard it....
