Coilover spring helpers
Old May 3, 2011 | 04:11 PM
capri280's Avatar
capri280
Default Coilover spring helpers
Need a bit of help folks
Have two sierra's one fitted with a set of std gaz coilovers and the other with a set of gaz golds
What i need to know do i or should i also set a set of spring helpers with these
And secondly where would i get ones
Regards
Eugene
Old May 3, 2011 | 04:29 PM
charlie luciano's Avatar
charlie luciano
Suspension should be fine as it is fella also not too sure if you can get small enough spring assitors to go in a coil over spring
Luciano
Old May 3, 2011 | 07:18 PM
cossie604's Avatar
cossie604
I'd fit them personaly...Im having trouble with my Avo coil over springs coming away from their seat, so I really could do with a set of helpers for them tbh. Think you can get them from most tuning shops, tried RandB motorsport? You just need the springs and collars I believe.
http://www.randbmotorsport.co.uk/
Old May 3, 2011 | 08:09 PM
Ridgey's Avatar
Ridgey
When you jack the car up the back springs tend to fall out of place (whick is a pain when lowering car back down), i've fitted some to my rear Std GAZ coilovers, got them from Rally Design i think.
Don't cost a lot.
And as long as you have a centimeter or so more threads below the spring platform you'll be fine.
Old May 4, 2011 | 02:10 PM
Paul_RS's Avatar
Paul_RS
Spring helpers and helper springs are two different things...
Fred Crawford in Larne has helper springs on the shelf. As Charlie Luciano says, i don't think you can get spring assistors for coilover springs, don't see what you'd want or need them either?
I've helper springs on my Bilsteins
Old May 4, 2011 | 05:29 PM
cossie604's Avatar
cossie604
I was reading between the lines regarding the op's terminology
Old May 4, 2011 | 05:36 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
no idea what they are lol but my gaz coilovers dont have any and there fine jacked up or sat on the road!
Old May 4, 2011 | 10:29 PM
Paul_RS's Avatar
Paul_RS
not saying anyone is wrong, he just needs to clear up exactly what he wants
Old May 5, 2011 | 12:12 PM
cossie604's Avatar
cossie604
If he posts up about fitting a tow-bar then we'll know for sure what he means
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
CrOwSoN15
Sep 24, 2015 01:36 PM
Adam Graham
Sep 6, 2015 06:04 AM
