2wd diff on 4x4
Apr 27, 2011 | 09:23 PM
2wd diff on 4x4
Is it ok the use a 2wd rear diff on a 4x4?are they the same ratio
cheers
Apr 27, 2011 | 10:24 PM
they are different ratio but so close you wouldnt notice i have 2wd rear on my 4x4
Apr 28, 2011 | 07:39 PM
As said sure the 4wd is 3.64:1, the 2wd 3.62:1, might be the other way around, but you will not notice any difference it's so slight.
I'm sure the top rear mounting will need cutting down about 1/4" at each end as is wider on a 2wd.
Apr 28, 2011 | 08:58 PM
Yea found that out last night when I went to fit the 4x4 diff, stage 3 beam is for 2wd!
May 1, 2011 | 10:08 PM
Is the 2wd one stronger???
May 1, 2011 | 11:14 PM
Quote:
Originally Posted by
Rob Virgo
The 2wd one is 7.5" and will take more abuse.
Brettski you will just need to fit a spacer to the upper left mount point on the 4wd diff to fit in into a 2wd beam.
May 2, 2011 | 01:38 PM
NEIL A
Cheers yea on the hunt for a top bolt now
May 2, 2011 | 07:33 PM
Brettski mk2
I can't remember if it a all the way through bolt, but if it is can use studding if you get stuck.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
mark r
Sep 29, 2015 07:27 PM
rog
Sep 16, 2015 03:00 PM
