FRST Parts (A Few Needed) also some advice.
Hi guys i need a few parts for my FRST. I am willing to collect if you are not too far or pay for postage. Cash waiting. Parts needed are as follows
. I didnt want to clog the site so i put it all in one thread. Im not a mechanic so i could be wrong about a few thing but i will appreciate any help
1. Alternator
2. ISCV
3. Master cylinder
4. Decent set of HT Leads
5. Beige Injectors
6. (OFAB) 195 Chip (I think)
7. Passenger side front light (With intact bracket)
Im not sure whether my car is ofab or ofac but i took a picture of what i think to be the map sensor and it looks sort of like the cosworth one. (Also would my car run if i had an OFAB Map sensor and an OFAC Ecu? As my car runs quite lumpy. (When its not revving its bollocks off due to the ISCV being stuck open lol. It also jolts a low speeds and sort of an off and on effect at higher (Accelerator)
http://i1101.photobucket.com/albums/.../IMG_00451.jpg
http://i1101.photobucket.com/albums/.../IMG_00471.jpg
1. Alternator
2. ISCV
3. Master cylinder
5. Beige Injectors
hi mate ive got a iscv you can have for Ł15 posted.
if you remove your ecu you will be able to see what management it is but it sounds like you have ofab as the map sensors do look like cossie ones
ive got pretty much everything you need im in hertfordshir give us a shout 07976677447, i have a alternator, iscv, blue injectors if thats of any use, ofab and ofac and mix and match ive read i can also have a master cyinder for you out of another fiesta im brekaing its a 1.6 zetec 16 valve conversion out of a mk5 escort.
155lee
Sep 14, 2015 07:37 PM
