Cam Cover Refurb
Old Apr 27, 2011 | 12:09 PM
PYE WHITE's Avatar
PYE WHITE
Default Cam Cover Refurb
Guys,
Have any of you refurbished a cam cover for a Cosworth before? If you have could you give me some advice, I will be doing mine soon but I have never done anything like that before.
Pye
Old Apr 27, 2011 | 02:27 PM
bad boy rs's Avatar
bad boy rs
I've done a few, mate of mine does powder coating so 25 quid for that then 30 quid machining. This is the last one I had done
Old Apr 27, 2011 | 02:38 PM
PYE WHITE's Avatar
PYE WHITE
That looks nice, I thought about doing mine crackled black.
Old Apr 27, 2011 | 02:39 PM
cozzy jeff's Avatar
cozzy jeff
powdercoats the way to go.
Old Apr 27, 2011 | 03:37 PM
PYE WHITE's Avatar
PYE WHITE
That does look good Jeff, has it been lacquered as well?
Old Apr 27, 2011 | 04:05 PM
cozzy jeff's Avatar
cozzy jeff
no mate straight from the oven.
Old Apr 27, 2011 | 06:48 PM
rs2klee's Avatar
rs2klee
K***LMT
looks well nice that jeff..
Old Apr 27, 2011 | 07:01 PM
PYE WHITE's Avatar
PYE WHITE
Agreed, it may well be the way forward.
Old Apr 27, 2011 | 07:22 PM
bad boy rs's Avatar
bad boy rs
jeff your coating looks much much better than mine
Old Apr 27, 2011 | 07:32 PM
rsmark86's Avatar
rsmark86
powdercoating all the way, im getting my rocker cover / header tank/ power steering tank and strut brace done in black and ive got the spec r breather system in black aswel...
i think gloss black is the best colour to do it, but its upto you what you want
Old Apr 27, 2011 | 07:36 PM
jaimesdna's Avatar
jaimesdna
my powder coated one. was alto cheaper & easyer to not have the letters done (also looks a bit different
and the one i recently did for my other cossy. only cost Ł7 to do & that was for the wrinkle black paint. sanded the silver with 320 grit wet n dry then just painted the letters with a small brush
Old Apr 28, 2011 | 03:16 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
heres mine i did a few years ago. did 7 layers with a gloss rattle can, cant remember what make it was and then hand brushed in the letters in the blue and red then carfully rubbed down the metal around the lettering.
Old Apr 28, 2011 | 06:22 AM
BRAMMER's Avatar
BRAMMER
Si i got my cover blasted back to bare metal, etch primed and painted with this wrinkle paint
http://cgi.ebay.co.uk/PJ1-BLACK-WRINKLE-TEXTURE-COATING-HIGH-TEMP-PAINT-DASH-/390237248880?pt=UK_Motorcycle_Parts&hash=item5adbf 3dd70
After that was done i got e top machined down - any machine shop should be able to do this
But here's mine
Old Apr 28, 2011 | 06:36 AM
cozzy jeff's Avatar
cozzy jeff
to save paying for a machine shop to machine the top of the cam cover down use one of these and do it yourself,you can also get them to fit into a grinder which i found to be easier,although i do like the machining affect on your brammer.
http://cgi.ebay.co.uk/100mm-Drill-Ab...item20ace68f0b
Old Apr 28, 2011 | 09:16 AM
PYE WHITE's Avatar
PYE WHITE
I do like the blue Ford badge and the red lettering, but I also think Chris's looks a little understated which I like a lot. Although I'm not sure if that was the look you were going for lol. I think I may have to do a mixture of both to be honest.
Cheers for the inspiration guys.
Old Apr 29, 2011 | 09:06 AM
Albino Deano's Avatar
Albino Deano
FROZEN WHITE FRS No2676
Stipped mine down to bare metal then spay painted blue and lacquered.
Old Apr 29, 2011 | 09:17 AM
4x4 S2 Cossie's Avatar
4x4 S2 Cossie
Powdercoat all the way. Here's mine...
Cheers, Chris
Old Apr 29, 2011 | 09:31 AM
DaveCrack's Avatar
DaveCrack
Powdercoating atw! Lasts way longer then painted with a rattle can...
Old Apr 29, 2011 | 11:32 AM
scoobydooby914's Avatar
scoobydooby914
How are people Re facing the bare metal part? Are most people getting them machined or just blocking them back with sandpaper
Old Apr 29, 2011 | 11:38 AM
DaveCrack's Avatar
DaveCrack
Machined looks way nicer, but you can also sand it down.
Mark RS
Mar 5, 2021 06:08 PM
