Rear Brake Dust guards
Has anyone removed theirs and kept them off?? if so is the dust etc a REAL issue?? as mine are alittle rusty and i'm fitting new discs pads & callipers and just wondered if i'd be ok just to leave them off.
Thanks..
Thanks..
mine been removed for couple years now,
no issues i have noticed and car used all the time,
mot guy has never said anything either,which was my biggest worry
colin
colin
As pointed out by Charlie L, they are splash guards, to try and stop water getting on the discs, between pads and disc, they're on the wrong side of the caliper for dust guards!!
There can be a momentary loss of brake if the rear brakes are waterlogged, but if running grooved/drilled this won't be an issue as water gets squeezed away, only in reality a problem when the wheels have been through a small stream/ford rather than normal rainwater.
I've always taken mine off, due to my metro always getting stones stuck between guard and disc and grooving the disc.
Adam Graham
Sep 6, 2015 06:04 AM
